Old 11-22-2009, 12:54 PM   #1
creamsicle68
custom gauge clusters?
hey guys. i just pulled the whole dash outta my truck and im gonna rewire the dash with all new gauges. im kinda stuck for ideas and what gauges to get so if you guys could post up some pics of your aftermarket gauges and custom dashes that would be awsome and help a ton. or if you guys have any suggestionson were to get the gauges that would be awsome to. Thanks
Dalton
creamsicle68 is offline   Reply With Quote
Old 11-22-2009, 01:22 PM   #2
keith61760
keith61760's Avatar
Re: custom gauge clusters?
Here is what I did in my 77. Its basically Equux gauges from Kragen in the the stock housing.
Here are a couple threads that have good info on gauges and a bunch of ideas. The second thread has some good ideas I wish I had seen before I did mine.
http://67-72chevytrucks.com/vboard/s...d.php?t=331910
http://67-72chevytrucks.com/vboard/s...d.php?t=180608
1977 Chevy Cheyenne 2wd SWB
keith61760 is offline   Reply With Quote
Old 11-23-2009, 03:57 AM   #3
andrewmp6
Here is a nice write up http://www.73-87.com/7387garage/inte...ge_surface.htm or http://www.73-87.com/7387garage/inte...s_recessed.htm or http://www.classicdash.com/shopping/home.php?cat=191
andrewmp6 is offline   Reply With Quote
Old 11-23-2009, 07:16 AM   #4
78-5.3
78-5.3's Avatar
i like that what did you have to do to install them????
78-5.3 is offline   Reply With Quote
Old 11-25-2009, 10:47 AM   #5
keith61760
keith61760's Avatar
Photobucket is blocked at work so I copied a link to the post with the pics I am refering too.
I cut the black metal piece that goes over the stock gauges so I had a spot to mount the smaller ones. Then I cut a piece of metal to mount the speedo and tach.
http://67-72chevytrucks.com/vboard/s...8&postcount=11
This post shows the cluster going back together and the wiring on the back. Not my best wiring, I will prob redo it this winter.
http://67-72chevytrucks.com/vboard/s...3&postcount=24
I still have to make some adjustments to the gauges. They are off enough to annoy me. Also in that thread I took pics of the LED's I will use for the high beams, turn signals and parking brake warning.
Old 11-25-2009, 12:03 PM   #6
OJOE
Crew Cut
OJOE's Avatar
i went digital
85 SWB 1/2 TON CREWCAB/5.3
03 CHEV 3500 DURAMAX CREW CAB
85 CHEV SWB/TPI
06 CHEV TAHOE (WIFES)
30 MODEL A HOT ROD
07 HARLEY DAVIDSON BAGGER
09 STREET GLIDE
AN D A LOT MORE JUNK
OJOE is offline   Reply With Quote
Old 11-25-2009, 12:13 PM   #7
menace121978
menace121978's Avatar
hey ojoe! hows that working for ya anyway? been thinking of going that route myself.
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 11-25-2009, 12:22 PM   #8
JohnC
JohnC's Avatar
My uncle put the Dakota digital dash in his too, and loves it.
JohnC is offline   Reply With Quote
