11-22-2009, 03:53 PM | #1 |
Turbo Guy
9 inch swap
I am toying with the idea of doing a 9 inch in my truck since I keep breaking stuff. Anyone have any advice on this? I found a 79 f150 with almost the perfect width 65 1/4, but the ford pinion offset bothers me. I read a couple of threads where guys have one side narrowed to centre the pinion, and some others say just leave it. I have a one piece shaft and not alot of room around it in the crossmember so I'm not sure if I have the room to run it on an angle, and I don't really want to go thru the hassle of narrowing a diff. Anyone done this swap?
1972 Gmc Custom swb intercooled twin turbo 327 10.5-1 and 12 lbs of boost, Nodular iron case super t-10 4 speed with a blowproof bellhousing, 12 bolt eaton posi soon to have moser axles. 1998 Honda CR250 fully ported, case matched, milled head, vortexed carb and revalved suspension but don't forget the woody woodpecker decal kit! Things I've broken so far: 12 bolt diff saginaw 4 spd many, many pieces Aluminum case Super t-10 4 spd |
11-22-2009, 11:43 PM | #2 |
Re: 9 inch swap
I've got a 70's Lincoln 9" in my 68 and the offset isn't that much, maybe 4" or so. I've got a 2 piece drivshaft so clearance wasn't an issue for me.
You could take your driveshaft loose and lay it over to the side and see how much room you've got. I bet you could make the crossmember hole bigger if needed and it wouldn't hurt anything. If you haven't bought the truck axle yet, go find a 70's Lincoln, they're the right width and have a 5x5 bolt pattern and disc brakes. I bet the LTD's and Mercury whatevers are the same rear with drums.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ Last edited by clay68c10; 11-22-2009 at 11:46 PM. |
11-23-2009, 01:11 AM | #3 |
Re: 9 inch swap
the dana axels are pretty tough to break try them
11-23-2009, 02:51 AM | #4 |
Turbo Guy
Re: 9 inch swap
clay68c10 thanks I was thinking the same thing. I had a look at it tonight and I will try moving the shaft over to see what its like. I want to stay with the truck diff because they are 31 splines versus 28 for the cars and my wheels are 5 on 5 and 5 on 5.5 so the truck will work.
tecky11 the dana 60 is tough but it is tough to find around here, the 9 inch is still pretty common in junkyards locally
11-23-2009, 02:58 AM | #5 |
Re: 9 inch swap
oops didnt see that your from canada!
11-23-2009, 03:26 PM | #6 |
TOTY 2006
Re: 9 inch swap
I am also running a 9 in my 67. came out of a 75 lincoln, so it has 5 on 5, rear disc brakes, and 3:00 gearing. no power off the line, but fast and quiet on freeway....
11-25-2009, 12:07 AM | #7 |
Turbo Guy
Re: 9 inch swap
John fabris did you just leave the offset pinion alone and just let the driveshaft run to the side?
11-25-2009, 12:47 AM | #8 |
Re: 9 inch swap
I ordered mine so i did not have to worry but i would cut the ends off, center the housing, have someone weld up new ends or the old ones in a jig. Make sure they can weld and have a jig to do it. Then order new axles. I do not think you will have a prob.
69 c-10 BBC 462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build. |
11-25-2009, 01:03 AM | #9 |
Re: 9 inch swap
Yeah, that 28 spline thing... Kinda sucks but it's not too tough to upgrade. New spider gears and axles is all.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
11-25-2009, 02:35 AM | #10 |
TOTY 2006
Re: 9 inch swap
I did not change anything and let the new one-piece driveshaft sit offset. Close clearance, but I have not had any problems with it. My truck is lowered 6" in back so I really don't have much travel to really swing the driveshaft...
11-26-2009, 04:10 PM | #11 |
Turbo Guy
Re: 9 inch swap
Thanks John, thats exactly the answer I was looking for!
