Old 11-22-2009, 04:09 PM   #1
Pont406
New brake hoses.
So much for a disc brake conversion. Everything was new or rebuild but spindles. About 1000 miles on this set up. I got real lucky this happend in my driveway after a short run to test trans shifting after modifying th400 governor. I don't want any braided stuff on my 69 but looks like i'll have to go with braided hoses.
Pont406 is offline   Reply With Quote
Old 11-22-2009, 04:57 PM   #2
vectorit
What?
vectorit's Avatar
Re: New brake hoses.
Those rubber brake lines are the most overlooked things IMO when people redo their brakes... I'm glad you didn't experience that failure while trying to stop at speed on the streets.
I don't care for the braided hoses, mainly because I want everything to look OEM. So I went to my local "Hose man" that fabs up all kinds of industrial hose and fittings, and brought in my old stuff and had them make up 2" longer replacements with correct rubber brake hose. Since the OEM's I think are too short for my burb.
EDIT: I just noticed you are in SoCal... Here is the shop I went to for my work.
http://www.hose-man.com/sys-tmpl/door/
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 11-22-2009, 08:48 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
That was a new hose that broke?
What exactly happened?
I've seen old dry rotted hoses that are still working.
Keith
Convert to disc brakes.
Old 11-22-2009, 08:50 PM   #4
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
i put nasty old hoses on mine...
ps, post the link to where your gettting braided hoses....I need some mine are 40 YO
John
1999 Toyota Tacoma 4x4
Old 11-22-2009, 09:23 PM   #5
Pont406
Yes, new hose. It had a 3 month warranty. I called summit with no luck. I'll try an inline tube tomorrow.
Old 11-22-2009, 09:26 PM   #6
lolife99
lolife99's Avatar
Did the hose rupture or is it leaking at a fitting?
Keith
Old 11-22-2009, 09:33 PM   #7
vectorit
What?
vectorit's Avatar
That was a new braided hose that failed???
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 11-22-2009, 09:57 PM   #8
oldblue1968chevy
lukcyhenrickson used braided on his truck...ima look for his build in a minute..cant remember where he got em.
where you folks gettin your lines at?
parts stores didnt have any..
John
Old 11-22-2009, 10:32 PM   #9
Pont406
It's a stock replacement hose.
Old 11-22-2009, 10:48 PM   #10
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Auto Zone shows universal Stainless hoses on their web site.
http://www.autozone.com/autozone/cat...s&pageNumber=1
And if you go to Russell's web site they show them available in black so they blend in more if thats what you are going for.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 11-23-2009, 10:33 AM   #11
rlm316
rlm316's Avatar
When you did the conversion, did you reroute the hard lines to the proper locations on the frame for disc brakes? If you left them in the same location as the drum brakes, when you attach the hoses they will bind or over extend and tear.
rlm316 is offline   Reply With Quote
Old 11-23-2009, 10:38 AM   #12
mbgmike
Any brakquip dealer can make any length you want.
mbgmike is offline   Reply With Quote
Old 11-23-2009, 10:49 AM   #13
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
That's exactly what he did. Notice the brake hoses are going to the back of the crossmember. On all factory disc brake trucks from 71 and newer, the brake hoses go to the front of the crossmember. He converted to discs and reused the old drum brake line mounting spot, putting the hose in an awkward installation.
Old 11-23-2009, 01:18 PM   #14
lolife99
lolife99's Avatar
My disc brake swap on my '69 uses ECE's conversion brake hoses. They work fine in the original drum brake "steel line" location.
Keith
Old 11-23-2009, 01:21 PM   #15
lolife99
lolife99's Avatar
Here's a few pics of mine,...
Keith
Old 11-23-2009, 01:26 PM   #16
dznucks
dznucks's Avatar
I was using the ECE disk brake lines in the stock location. Now i had some made at a Brakequip dealer. They are still in the stock locations but i am using a different banjo to reduce the stretch and strain on the hose.
Its actually cheaper to have some made at a brakquip dealer than to buy from russell or summit.
dznucks is offline   Reply With Quote
Old 11-23-2009, 01:39 PM   #17
mbgmike
We are in the auto parts business and we tell that to people all the time. Seems like people do not believe us most of the time. If their is no dealer close it makes sense but why spend more?
