11-22-2009, 04:11 PM | #1 |
Another Day, Another Dollar
front end in a '78 camper special?
i'm thinking about doing some crossover steering when i get home, and i'm trying to figure out weather or not i need new knuckles....
i think i have a 44 up there, but i can't remember how many bolts are on the cover. can somebody help me out here? i know that there is a 14 on the rear, 454 th400...
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box "its hip to be square" Last edited by willett; 11-22-2009 at 04:11 PM. |
11-22-2009, 04:22 PM | #2 |
Re: front end in a '78 camper special?
If i remember right there should be ten bolts. and if you have a right side knuckle that has a flat top you can have it machined for the studs. I you don't you will need new knuckles. I have a matched set extra sitting in the shed.There used to be a axle id chart on coloradok5.com in the spec section .
1989 jimmy "U.A.V" 44/14blt 4.56s locked up 37's 1984 2wd swb 1969 swb 4x4 |
11-22-2009, 05:06 PM | #3 |
you will need new knuckles, the flat top pside was only used till 75.
being a 78 it should be a 10b axle but it could be a d44, doesnt matter. you will need both knuckles because the tierod enter from the top on 75 and ealeir knuckles. but you will only need to swap the knuckles, EVERYTHING ELSE WILL WORK !!!!!!! Last edited by 2tons of fun; 11-22-2009 at 05:06 PM. |
11-22-2009, 05:07 PM | #4 |
Think your truck might be too new to have flattops. Might even have a 10 bolt and not the Dana 44, but you could get a 44 up to 80, so anything is possible.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 4” SAS 1999 GMC Yukon 350/4L60 6" SAS |
11-24-2009, 03:35 AM | #5 | |
if you brothers aunts cousin has a 84 with a d44 and flat tops it because some one put that axle in the truck. |
11-24-2009, 06:10 AM | #6 |
Sb 400 club
Most likely a 10 bolt. They made the switch in 1977. Course they could of used a 44 but unlikely. Way to tell is if the diff chunk has "ears" on the bottom. If so its a ten bolt. For the cross over you will need flat top knuckles out of a Dana 44 pre75 i think. I would checkk on CK5 or wheeling dixie or one of the other 4x4 boards part section. Heck you can even try on here maybe pirate4x4...
here is a pic of the ears on the bottom ten bolt
1984 chevy c10, built 400sb,.(SOLD) 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
