Vent spring
Isn't there a spring that goes from the vent flap to the cowl frame? IF so does anyone have a pic or know how long it is?
"85" Monte Carlo SS "71" K5 (SOLD) "64" Chevelle 1930 Chevy two door rat Last edited by Bentblazer; 03-08-2011 at 09:28 AM. |
Re: Vent spring
Just checked mine, I do not have that piece at the bottom of my cowl tray you show in the pic. I assume you have A/C, I do not, you didn't say. The only vents I have are inside the cab on the kick panels. Maybe someone with A/C can chime in.
'71 ![]() "If life was fair you'd be able to afford one of each and a garage large enough to house them all." |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Re: Vent spring
I dont have ac?? I assume you do have ac as my cabs do not have that piece..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
Future TOTM Winner
Re: Vent spring
Here it is. This pic is from my 69 parts truck with A/C. I don't know the length, but maybe I can measure when I get home.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com Last edited by Critter; 11-24-2009 at 05:20 PM. |
Re: Vent spring
honestly the vacume actuator has enough of a spring inside you really dont have to worrie about it... at least mine didnt need one, i just replaced the actuator like two hours ago, $48 bucks owtch
Re: Vent spring
Thanks for the help guys, I took some measurements and it looked real close to a carb linkage spring and wasn't to strong. Going to give that a try and see, thanks again.
"85" Monte Carlo SS "71" K5 (SOLD) "64" Chevelle 1930 Chevy two door rat |
