11-22-2009, 07:53 PM | #1 |
FS Rear cab trim “paint divider”
I have three good sets of trim for the rear of the cab "paint dividers". Good driver condition. I had about ten sets and after sorting, this is what I have left, all three are three piece sets. $15.00 each set plus shipping.
I parted out ten 67 – 72 trucks, I have a garage and a storage building full of parts I need to sell, send your request. Please reply in this thread to reduce confusion and maintain the integrity of this forum. Dasani |
11-22-2009, 08:46 PM | #2 |
Re: FS Rear cab trim “paint divider”
Do you have any c-10 emblems that go on the fender and 350 badges thanks
11-22-2009, 08:54 PM | #3 |
11-23-2009, 09:29 AM | #4 |
bump
11-23-2009, 02:46 PM | #5 |
need 72 air cab, rust free..?????
1971 K5 CST Blazer 1951 -3100 5 window short bed 4sp 1965 Chevelle Malibu 283 (sadly sold) 1968 Camaro 327 1968 Honda mini-trail z50a #377 1966 uh 1-D Huey |
11-23-2009, 11:16 PM | #6 |
11-24-2009, 05:12 PM | #7 |
Do you have a 67/68 hood in good condition?
11-24-2009, 08:47 PM | #8 |
11-24-2009, 09:16 PM | #9 |
I will be visiting a friend in NC in January and will pick it up.I need several other parts as well and will give you a list on saturday.
11-25-2009, 11:40 PM | #10 |
11-27-2009, 04:54 PM | #11 | |
Here is the list: Radiator support for 68 C-10 Driveshaft including transmission yoke for C-10 shortbox with TH350 auto tranney Both bare door shells Both inner plastic 68 door panels Both door mirror arms w/3 screw mounting plates, chrome or painted, ref. LMC # 38-5852 Front stepside bed panel Power steering box Master cylinder w/brake booster & prop valve Both front stock spindles with 5 lug disc brake setup Both 5 lug rear axle shafts or 5 lug 12 bolt differential housing Driver side rear fender w/ spare tire cutout and spare tire bracket. Front sway bar with front frame brackets Last edited by mup123; 11-27-2009 at 05:36 PM. Reason: forgot one part |
11-27-2009, 09:41 PM | #12 | |
Here is what I’m sure I have and will have ready for you. After I get back and look at this stuff I'll giv you a price by part.
1- 67 or 68 hood 2- Five lug, power brake front end; 72 C10 upper and lower control arms, Spindles, Brake calipers and rotors (I’ll put all the small nuts and bolts in a bag for you) 3- Power brake booster with bracket, master cylinder and proportioning valve 4- I have a five lug housing from a 72 two wheel drive blazer (you would have to use conversion axles with your ‘68 housing) (I may get a 71 ˝ ton this coming week, if I do that will be your housing) 5- Power steering box from the same 72 the brakes are on. Here is what I don’t have (for sure) DOORS, I’m going to look at three tomorrow (two passenger side and one driver side) If they are useable I’ll still not have a drivers door to let go. I’m going to look at a truck tomorrow or Sunday the guy wanted to sell or part it, it is a ’67 short step and I think it had a good fender with the cut out but no marker. I tried to buy the bed but he wanted far too much for it. The truck has been sitting for a while (no bites) and he wants to sell it to get out of his yard so if the price is right I may have that for you too. If that fails, I know were two beds are in a yard (in Alabama) they are nice and the guy knows it, I’d have to get both of the beds or nothing. So to get your bed parts I’ll either have to buy a truck or two beds and I think the truck will come easer. I have three good 67-68 core supports but I’m going to keep those with my two trucks and the front clip I have for my Blazer. I have a fourth but, it has some rust under the battery tray and would need to be patched for me to use, I’ll send you pictures when I get home, It isn’t bent and isn’t going to scrap it is a good “drive” piece to me. I may or may not have a complete V8 (two piece) drive shaft. All the V8 350 turbo, short-bed trucks I’ve had are gone, sold (yes I have separation anxiety) I’m sure I have the front part and a yoke for you I have to look around and measure. I had a short-box 400 turbo so, I’ll look for the back part of that drive shaft. I’ll look in my junk for the mirror arms and “nut plates” I had a set but they may have gone with a truck. I’m not sure which door panels you are looking for, I have a nice set from a 68GMC but they are not hard plastic. I can get pictures of that too. Do have shifter linkage and a transmission crossmember? Tom Quote:
11-28-2009, 05:40 PM | #13 | |
I do have the shift linkage which fits to the transmission, the piece which bolts to the chassis and the linkage from the column , but not the piece which goes between the transmission and the frame john dooling |
11-28-2009, 05:54 PM | #14 |
I do have a transmission crossmember.
11-29-2009, 09:25 PM | #15 |
Hey Mup, I got some pictures and some bad news, the 68 core support I have is trash. I'm still looking. I bought a 69 step bed on my way home tonight but not the correct fender for you sorry, I'm working on it. One of the members has/had one I'll give you his info as well as for the core support I'll give you his info too - I'm going back to my mom's (Alabama) in three weeks, if they have what you need a you work a deal with them I'll pick the parts up for you. A local guy has two new doors would you be interested in them?
Found the mirrors and nut plates, I'll send pictures cam you send me your email address that will be easier. D |
11-29-2009, 10:38 PM | #16 | |
12-01-2009, 09:31 PM | #17 | |
Thanks Tom |
12-01-2009, 10:21 PM | #18 |
do you have 72 am-fm radio?
72 Chev Cheyenne Super SB 4x4 350,4spd,buckets, tilt,tach,am-fm,extreme tow hooks,Canadian Model Production 1 of 52 SOLD 70 Chev CST, 350 auto, PS, PB, AC, tach |
12-01-2009, 11:07 PM | #19 |
12-02-2009, 11:52 AM | #20 |
12-02-2009, 01:16 PM | #21 |
Thanks Dasani for looking, will keep searching for one
Cheers
12-02-2009, 01:51 PM | #22 | |
Last week you requested my email address to send pics to me. I never received them. I am also waiting for prices on the items you do have, ref: items 1, 2, 3 and 5. I will pass on the Chevy Blazer rear axle and waiting for news on the other items on my list. Thanks, John Dooling |
12-02-2009, 02:58 PM | #23 | |
John I sent an e-mail with some pics I'll look it up and resend it. |
12-02-2009, 09:21 PM | #24 |
12-02-2009, 10:02 PM | #25 | |
For some unknown reason I have not received any emails from you. I checked my junk mail and nothing there either. Please try to send to my other email address which is: JJdooling@hotmail.com. I'll stand by |
