Old 11-22-2009, 08:33 PM   #1
ges55
BLACK SATIN
ges55's Avatar
double pulley
I have a double crank pulley on my 67 250 ci w/manual steering. I was wondering if it is there for power steering? Thanks for any help.
67 C10 Fleetside LWB-283, 3 on the tree,power assisted steering, father-in-law bought it new
67 C20 Fleetside LWB-'85 305 V8 (original was 250 6 cyl), Holley 600 carb, full length Hedman headers, dual exhaust behind the back wheels, 4 spd , manual steering
85 C10 Silverado- 305ci
ges55 is offline   Reply With Quote
Old 11-22-2009, 08:49 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: double pulley
Do you actually have a pulley ? Most inline engines just use a harmonic balancer with either one or two belt grooves.
Old 11-23-2009, 09:26 AM   #3
ges55
BLACK SATIN
ges55's Avatar
Re: double pulley
It's probably what you say, it has 2 grooves.
Old 11-24-2009, 11:06 AM   #4
ges55
BLACK SATIN
ges55's Avatar
Re: double pulley
What is the 2nd groove used for? I'm looking into putting power steering on it & am trying to figure out what I need. I've looked at alot of pix of 250 cis on here & have seen some differences in the way they are mounted. Where is the pump supposed to be mounted? Also do I have to change my alternator pulley? Thanks for any help or pix.
Old 11-24-2009, 02:10 PM   #5
ges55
BLACK SATIN
ges55's Avatar
Re: double pulley
ttt
Old 11-24-2009, 02:57 PM   #6
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
Re: double pulley
Somewhere in the 70's Chevy increased the spacing between the grooves on the harmonic balancer/pulleys on the inline 6. I discovered this when I obtained my PS setup from a 79 passenger car. The space between the grooves on the balancer & the space between the grooves on the pulley are distinctly different. I still just installed it all & despite the slight misalignment, I still have yet to throw a belt. In hindsight, I should have gotten the the balancer from the donour.
However, if you can get a PS setup from a donour from a pre-wide spacing year vehicle, you are laughing. The pump bracket attaches to the head on the front & top, has a "leg" that runs down behind the alternator to the block, and the pump bracket also has a slot where the alternator bolts to for adjustment. You need not change the alternator pulley.
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
Old 11-24-2009, 03:23 PM   #7
ges55
BLACK SATIN
ges55's Avatar
Re: double pulley
That helps. Thanks alot for the info, PASS. Could I trouble you or someone else for a pic?
Old 11-24-2009, 03:38 PM   #8
passthebuck
Re: double pulley
Photos.
passthebuck
#5642
Old 11-24-2009, 04:32 PM   #9
ges55
BLACK SATIN
ges55's Avatar
Re: double pulley
That's what I wanted to see. Thanks very much for the pix!
