Old 11-22-2009, 10:45 PM   #1
hahaudriveachevy
hahaudriveachevy's Avatar
What axle do i have?
I have a 65 1/2 ton gmc and i would like to know how to identify what axle i have and if i need to chance it to a 12 bolt.(im putting a 454 in it) It has leaf springs and its a 6 lug
1965 gmc
hahaudriveachevy is offline   Reply With Quote
Old 11-22-2009, 11:36 PM   #2
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Re: What axle do i have?
It is a 12 bolt 30 spline, to figure the gears you can take the cover off and count the teeth on the gears.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 11-23-2009, 12:11 AM   #3
blackedoutharley
GMC also installed Dana rearends in their 1/2 tons.
Could be either.
blackedoutharley is offline   Reply With Quote
Old 11-23-2009, 12:20 AM   #4
hahaudriveachevy
its not a 12 bolt i know that. It only has 10 bolts so im thinking its a dana does any one no how to find out if its a dana 44 or 60 or gm 10 bolt
1965 gmc
Old 11-23-2009, 12:49 AM   #5
198plus
198plus's Avatar
Maybe this will help..........http://www.coloradok5.com/axleguide.shtml
198plus is offline   Reply With Quote
Old 11-23-2009, 01:50 AM   #6
Captainfab
60-66 Nut
The 1/2 ton GMC's with the leaf springs typically had Dana 44's. Probably not the best differential for your application. Probably the easiest and most economical swap would be a 12 bolt. They will take a fair amount of abuse in stock form and there are lots of aftermarket parts available for them. If you want to stay with 6 lugs, look for one out of a pre 1980 K10 or K5 Blazer.
