12 Bolt disk brake conversion
Anybody know if someone else is going to make brackets for the conversion? I already have the camaro calipers. Wanting to get the brackets to complete the conversion. So if anybody has dimensions or can make these let me know. I know there are others on here wanting the same. Thanks
Re: 12 Bolt disk brake conversion
Try this. http://secure.chassisshop.com/partlist/6181/
I hope this is what your looking for. I made a set of these before i realized they existed. You can also search on dirt track websites and come up with all kinds of different configurations for both standard and metric calipers. |
Thanks for the info. I was hoping someone had dimensions for the LT1 camaro caliper brackets or had a set they werent going to use. Like the ones Glock was making. I have the 1977 12 bolt truck rearend, impala rotors and the camaro calipers. Now I need the brackets to put it all together.
#4 | |
Still plays with trucks
http://www.67-72chevytrucks.com/vboa...77#post3259777 They should share the LT1 rear caliper carrier bolt spacing.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
