11-23-2009, 12:15 AM | #1 |
What front end????
How can I identify what year model front end I have? I bought an unfinished project and can't remember what year model he said the front end was.
11-23-2009, 12:30 AM | #2 |
Re: What front end????
Post a picture of the front end. Grills are different on numerus years, hoods are different. Post a pic and let everyone here give you an idea.
11-23-2009, 11:51 AM | #3 |
Sorry, by front end I meant spindles, rotors, brakes etc.
11-23-2009, 12:02 PM | #4 |
Ex-Minitrucker
Well if its 5 lug its the later years 71 & 72 I think. I know the older ones are 6 lug with drum brakes
11-23-2009, 12:19 PM | #5 |
I really hate wet sanding!
Or 73-87, if 5 lug, those parts with a lttle effort fit also. I would say you are going to have to find a known vintage front end to compare it to, the 71-72 are the same, as are the 73-87 with the exception that some have 1" rotors and some have 1.25" rotors (thickness of rotors that is, I believe in those years the spindles/ rotors/ and brakes are not interchangable). I don't know the thickness of 71-72 rotors off top of my head.
Jeff, 68 C-10 75 C-20, now a C-10! 10 F-150 |
11-23-2009, 04:24 PM | #6 |
Watch out for your cornhole !
71-72 had disc brakes and steel screw in control arm bushings.
73-87 had disc brakes and rubber control arm bushings. 73-87 upper control arms have a 3/8 hole in the front of them for the brake line mounting tab to screw in to which 71-72 do not. 71-72 brake lines run across the crossmember and mount to tabs on each side right in front of the crossmember. 73-87 brake lines did not run across the crossmember at all. They ran down the inside of the frame rails.
11-24-2009, 02:28 PM | #7 |
Thanks. That's what I was looking for. I have been reading on here for a long time and your knowledge of this stuff never ceases to amaze me.
11-25-2009, 06:50 AM | #8 |
Well said, tx f.f.
11-25-2009, 07:11 AM | #9 |
low n' slo
that single post should be a sticky...maybe with a pic of each. nice info
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
