Old 11-23-2009, 02:14 AM   #1
lsx72
Fi or carb?
im planning a ls swap in my truck and cant make my mind up which set up i want to go with. opinions would be appreciated.. is there anyone running a carbed ls engine with OD transmission with any mpg numbers? thanks,,robbie
lsx72 is offline   Reply With Quote
Old 11-23-2009, 06:52 PM   #2
lsx72
Re: Fi or carb?
nobody ?
Old 11-23-2009, 07:26 PM   #3
mycool72
mycool72's Avatar
Re: Fi or carb?
I wish I had a fuel injected motor in mine...cold days are a b....lol
mycool72 is offline   Reply With Quote
Old 11-23-2009, 08:21 PM   #4
rob32472
Re: Fi or carb?
EFI is only way to go IMO no more pumping the pedal, to rich smell, adjusting carbs, changing plugs, just driving... Ahhhhh thats y I am working on this swap
rob32472 is offline   Reply With Quote
Old 11-23-2009, 08:58 PM   #5
LONGHAIR
Re: Fi or carb?
From what I have seen, a carb swap is not a "cheap date"....
It requires ignition work too. There is no distributor, just coil packs that run off of a crank trigger and the computer. So, if you are eliminating the computer, which would be the only reason to run a carburetor anyway, you need a distributor. There is a kit made to do exactly this, but it's going to cost, and it takes a bit of tear-down on the front of the engine.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 11-23-2009, 09:37 PM   #6
eagleuh1
eagleuh1's Avatar
Re: Fi or carb?
Keep it FI. Much better for tuning with laptop and tuning software. Better milage, better running, most likely cheaper also. All around better drivability. thinking about taking my 2005 5.3 out of my S10 Blazer where its been 3 years now and putting in my 68 C20 this winter. Thats my .02 worth. Good luck however you go though. Either way your ahead of the old engine in my opinion. Jim
eagleuh1 is offline   Reply With Quote
Old 11-24-2009, 03:53 AM   #7
lsx72
Re: Fi or carb?
well the reason i cant decide is on one hand you got FI which equals good starting and better fuel economy which im not sure about because dont know what a carbed ls engine will do with an OD. on the other hand you got carbed which equals cam, spring, and head swap and get 500+ hp..
Old 11-24-2009, 11:23 AM   #8
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: Fi or carb?
Check out LS1truck, you can get that much and more with a little help from Summit on your 5.3 FI engine. You can also cram air down it's throat (supercharger) and some have 1000hp. Up to you and your wallet really.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
