Old 11-23-2009, 10:05 AM   #1
DANTIP
DANTIP's Avatar
BBC Help!
I am considering freshening up my 402 and I ran across a great deal on a NEW 2000 L-29 Vortec long-block crate engine. With a shipment from Summit and some assembly work, I could have a new 4-bolt-main, roller-cam 454 ready to drop in for less than $2,300. If I have my 402 rebuilt, I fear I would have to spend close to that for the disassembly, hot-tank, machine-work, bearings, cam, reworked heads, assembly, etc.
Do I store my 402 and install/drive the 454 or freshen up the 402 and not worry about having to store the original engine?
Am I missing any good alternatives here?
DANTIP is offline   Reply With Quote
Old 11-23-2009, 12:10 PM   #2
kwmech
Re: BBC Help!
I would personally want to keep the original engine with the truck
Old 11-23-2009, 12:12 PM   #3
turp mcspray
turp mcspray's Avatar
Re: BBC Help!
I would go 454. Save the 402 in case you want to sell the truck someday. A big block truck with the original engine is probably worth something to someone. Unfortunately a fully loaded big block truck is just not worth what a similar equipped car is worth. If you want to drive it, you will like the 454 WAY more than the 402.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 11-23-2009, 12:14 PM   #4
djracer
djracer's Avatar
Re: BBC Help!
Agreed!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 11-23-2009, 12:15 PM   #5
LockDoc
The Older Generation
LockDoc's Avatar
Re: BBC Help!
I am thinking about replacing the engine in my '70 Chevy slide in camper truck with a crate engine. If I do I will keep the original 350 in case a new owner might want to rebuild it. It does run but definately needs rebuilt.
LockDoc
Leon
