Old 11-23-2009, 10:13 AM   #1
burke117
edelbrock 1406 carb questions
the two adjustment screws in the front which does what? turning them left makes it run richer or leaner???
burke117 is offline   Reply With Quote
Old 11-23-2009, 10:41 AM   #2
pat 70/71
pat 70/71's Avatar
Re: edelbrock 1406 carb questions
,The screws are idle air adjustment screws turn each one in (slowly)one at a tlme until the motor starts to stumble. then turn the screw out until the idle levels out & then adjust the other one. when motor runs as smooth as it can run , your idle circuit is set. give it a try, hope this helps... Pat
pat 70/71 is offline   Reply With Quote
Old 11-23-2009, 11:35 AM   #3
67chevemall
67chevemall's Avatar
http://www.edelbrock.com/automotive_...all/1000.shtml
Just click on the two 1406 tabs
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
