11-23-2009, 10:51 AM | #1 |
Radiator Shroud
Will a shroud for a 4x4 bolt up to a non 4x4 radiator?
My 350 engine is set back in the 6 cyl location and I am trying to get the shroud closer to the fan. I hear that in a 4x4 the engine was set back in the 6 cyl location so I need a 4x4 shroud? or can you buy spacers for the fan? Thanks |
11-23-2009, 11:02 AM | #2 |
Between Trucks...
Re: Radiator Shroud
Don't know about the shroud, but you can get fan spacers. Try Summit.
Beat it to fit, Paint it to match... |
11-23-2009, 11:33 AM | #3 |
Re: Radiator Shroud
Sounds like you need to fab something up.
If you get two shrouds you could mate the two for double the lenght
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
11-23-2009, 12:26 PM | #4 |
Re: Radiator Shroud
From what Ive heard, the 4x4 shroud is exactly what you need. I just havent dropped the money to do it myself yet.
70 shortbed stepside "Schleprock" 350 w/TH400 rallys and BFGs -We can rebuild it, we have the technology-lower,shinier,faster |
11-23-2009, 02:57 PM | #5 |
425hp409
Re: Radiator Shroud
I am going to have a 72 4x4 Jimmy in my shop tomorrow and I will report back to you about the shroud. The thing to remember about fan shrouds is that the fan must be positioned about halfway in the shroud and halfway out of the shroud. This allows the fan to pull the maximum amount of air through the shroud. If the fan is too deep in the shroud it cavitates the air in the shroud. If it is too far out of the shroud, it will pull some air around the shroud, and not through it. I have repaired many overheating problems, especially with big blocks, by positioning the fan correctly in the shroud.
Charles 68 SWB, Dad bought new, now 396 & factory ac 64 Impala SS, 409 425HP, 4 speed AC 64 Bel Air Wagon, 400 Small Block 57 Bel Air all original 283 w/Factory Air 77 GMC Sprint, 454/425HP 67 Olds 442, all original 90 ZR1 Corvette |
11-23-2009, 03:20 PM | #6 |
Re: Radiator Shroud
From pictures that I have seen in parts catalogues, the 4x4 shroud is very different than the standard shroud and will not work unfortunately
11-23-2009, 03:23 PM | #7 |
Re: Radiator Shroud
So the fan pulls the air in and does not push it out the front, I guess that makes sense,but news to me!
11-23-2009, 05:37 PM | #8 |
Re: Radiator Shroud
I put a 350 in my '69 in the six cylinder location. I ordered a fan shroud part number 32-2820 from LMC for about $70. My fan sits about half in and half out of the shroud. I had to trim about 3" off the top because the blades were real close at that point. It was a straight bolt in and does what it is suppose to do. Hope this helps..
11-23-2009, 07:00 PM | #9 |
Re: Radiator Shroud
So 4x4 smallblock sits in a different position than a 2wd truck? I was hoping to be able to use my 2wd shroud on my 4wd conversion. I hate to buy a new shroud, mine is still pretty new
11-23-2009, 07:31 PM | #10 | |
Re: Radiator Shroud
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
11-23-2009, 07:41 PM | #11 |
Re: Radiator Shroud
Thanks, that is the part number I just ordered, how did you trim the top?
11-24-2009, 11:52 AM | #12 |
Re: Radiator Shroud
I just used an angle grinder. Didn't have to take much off. About a 1/2" wide and 3" long. Hope this helps. Tony D.
11-24-2009, 02:18 PM | #13 |
Re: Radiator Shroud
Thanks Tony,
My set up is the same as yours, 69 truck with a 350 in the 6 cyl spot. Did you have a long or short water pump and do you have a spacer behind the fan? |
11-25-2009, 12:25 PM | #14 |
Re: Radiator Shroud
Long pump with a 2" spacer. Turned out good. I was having a cooling problem due to the distance between fan and radiator. I keep reading articles on here, ordered what I have and it has worked well. These guys on here are awealth of info and will share ideas and lessons learned. Good Luck and hope you and your family have a great Thanksgiving and holiday season..
Tony D. (Portsmouth, VA) |
11-25-2009, 12:42 PM | #15 |
Re: Radiator Shroud
Thanks a lot Tony and again I have the exact same set up so I can't wait till the shroud arrives and hopefully it all works out as good as yours did. And like you said this site and the people on it like youself are the best. I guess I should subscribe and help out.
Happy Thanksgiving!!!! |
11-25-2009, 01:32 PM | #16 | |
Re: Radiator Shroud
RM
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288 Last edited by Rack Man; 11-25-2009 at 01:32 PM. |
11-25-2009, 03:11 PM | #17 | |
Re: Radiator Shroud
Not to disagree with Rack man, because he is correct
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 11-25-2009 at 03:12 PM. |
12-01-2009, 09:06 PM | #18 |
Re: Radiator Shroud
Tony D
Thanks for the advice. I just installed the shroud you suggested and it fits perfect and the fan is half in and half out as it should be |
12-08-2009, 08:18 PM | #19 |
Re: Radiator Shroud
jaro44sr - I'm going to be doing the chrysler/jeeep e-fan install as well, will it work with the 4x4 shroud? I didn't see any reference to that in 71Rat's FAQ page.
--------------------------------------------------------- I'm not crazy, I'm chosen, there's a difference. ---------------------------- '72 K10 SWB, 350, sm465/np205 ---- ---- |
12-08-2009, 09:20 PM | #20 |
Re: Radiator Shroud
Hi Tony, I have a 1968 c-10. My 350 engine also sits were the six cy. sits. I was having an over heating problem..I had a aftermarket electric fan as well as a clutch type fan. The fan was too fsr back from the radiator. I took out the clutch fan and now run the two fan aftermarket assembly. was this the right thing to do ?. I do not have a shroud on my radiator. my electric fan is on a on/off switch, not a thermostat switch. I f iforget to turn on the electric heat my truck can overheat at idle, also after i shut down my truck i sometimes have to leave the electric fan on for up to 20 minutes to bring down the engine temp. Anyone have any suggestions ? Was this method the best choice for my truck ?. thank you
12-08-2009, 09:33 PM | #21 |
Re: Radiator Shroud
Yes, I've installed the fan in both shrouds with equally good results. I ran a 1/4" strip of insulation before installing the fan
12-09-2009, 12:33 AM | #22 |
Re: Radiator Shroud
Good idea on the insulation. I'm actually attempting to mount the fan without drilling or cutting my shroud. We'll see how it goes...
12-09-2009, 02:06 AM | #23 |
Re: Radiator Shroud
post up some pics when you can, I'm curious to see other ways
12-09-2009, 02:58 AM | #24 |
Re: Radiator Shroud
More to do tomorrow, but just putting the fan in the shroud without bolting it in seems very secure. When I cut the tabs I left a bit to make it snug and tight. I may use different brackets in place of the silver ones, maybe one that will hook over the edge of the fan for extra protection.
--------------------------------------------------------- I'm not crazy, I'm chosen, there's a difference. ---------------------------- '72 K10 SWB, 350, sm465/np205 ---- ---- Last edited by dazza; 12-09-2009 at 03:00 AM. |
12-09-2009, 05:44 PM | #25 |
Re: Radiator Shroud
I was just scanning some other posts and found some saying the fan blades need to be half-in, half-out of the shroud. Is that for the stock fan? Should this be mounted at the back edge of the shroud?
Looks as if everybody that posted pics of their mopar e-fans has them dropped in a few inches.
