Old 11-23-2009, 09:15 PM   #1
57larry
Column Size
would a steering column from like a C50 grain/farm truck be the same length as a 1/2 ton C 10? (can you interchange?)
57larry is offline   Reply With Quote
Old 11-24-2009, 06:31 PM   #2
57larry
Re: Column Size
somebody gotta know
Old 11-24-2009, 06:34 PM   #3
marcsRX
68 C10 SWB
marcsRX's Avatar
Re: Column Size
i have the same question kinda. I need a new column in my 72 C10. Can i use a different non tilt column from a different truck?
marcsRX is offline   Reply With Quote
Old 11-24-2009, 07:46 PM   #4
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: Column Size
The c10 is 32 -33 depending on where you measure it. Even if the C50 is longer you can cut it down to size. Providing the shaft is 3/4" and not 7/8 or 1" you could use it.
dwcsr is offline   Reply With Quote
