Old 11-24-2009, 12:56 AM   #1
butterboy
Laying frame my way, with your help.
Hey guys long time forum watcher first time poster..I figured it's time. I just bought a new used plasma cutter(thermal dynamics) and need a good project to really use it. So with my stick welder in one hand and my plasma torch in the other I want to lay out the frame on my 70 c-10. Here is a quick run down of my truck. In the front I have three inch drop coils with 1-1/2 coils cut off of them and a disc brake convert. In the rear I have leaf springs, so I flipped my axle over the wore out leafs and did a 3 inch c-notch...So now my truck sits 9 inches off the ground. Now here is my thoughts for the front is to z my frame 3 inches and buy 73-87 3 inch drop spindles and bags to bring the front down to the ground...Now the rear...I have a 67 shortbed rolling frame with factory coils in the back. So was thinking about z-ing the rear 5 inches just after the back of the cab then bolting bags in place of the coils, adding a big c-notch and calling it a day. If your still reading this thanks..Here is a picture of my truck now.
butterboy is offline   Reply With Quote
Old 11-24-2009, 01:12 AM   #2
TylerHuff
TylerHuff's Avatar
Re: Laying frame my way, with your help.
nice truck. the more pics the better
1987 Gmc sierra
1962 Apache 10
TylerHuff is offline   Reply With Quote
Old 11-24-2009, 01:49 AM   #3
kev2809
low n' slo
kev2809's Avatar
check out the project section...puropedo did the exact same thing. came out great.
http://67-72chevytrucks.com/vboard/s...=362405&page=5
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 11-24-2009, 08:43 AM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
I am not a fan of Z-ed frames but it sounds like you are on track. My question is how competent are you with that stick welder? Unless you are very good with a stick, I would consider having someone else do the welding.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-24-2009, 10:04 AM   #5
butterboy
Well as far as me being able to weld with a stick welder, I have about 12years of good practice. I work in a machine/fab shop. This isn't my first rodeo, I am able to produce a good weld. What would you use mig/stick/tig? thanks guys
Old 11-24-2009, 07:29 PM   #6
mr48chev
mr48chev's Avatar
Nice truck there, that's just about as low as it could go and make it in and out my driveway right now.
Old 11-24-2009, 08:25 PM   #7
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
well if you bag it with a 2 3/4" cupped LCA and 3" dropped spindles your laying the X memeber on the ground hard......
now you have to change your rear to trailing arms then put a large C Notch in the rear frame for axle clearance then fab the bag mounts ..done
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 11-24-2009, 08:37 PM   #8
kev2809
low n' slo
kev2809's Avatar
i think he should already have trailing arms if he has springs
-_--_--_ _________
Old 11-24-2009, 08:54 PM   #9
Hottrucks
Hottrucks's Avatar
re read is first post
Old 11-24-2009, 10:14 PM   #10
rotgg
absolutely nothing wrong with zing a frame its been done since the beginning of hot rodding and is probably the easiest way to lay out one of these trucks many people don't even take the motor out to do the z
rotgg is offline   Reply With Quote
Old 11-25-2009, 12:05 AM   #11
kev2809
low n' slo
kev2809's Avatar
oops, i just read springs and assumed coil springs lol. sorry for the mix up
to the op... i think the only way to lay frame with ta setup is to notch the frame where the ta would hit...or you can do it this way but i dont think you will lay frame...
these pics were sent to me by another member so i hope he doesnt mind me using them..if you do just pm and ill take em down
-_--_--_ _________
Old 11-25-2009, 12:52 AM   #12
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by butterboy View Post
....What would you use mig/stick/tig?.....
Originally Posted by rotgg View Post
absolutely nothing wrong with zing a frame....
As I mentioned if your qualified you can do just fine with stick welding. My preference would be TIG, but a MIG will do the job too.
You are correct, there is nothing wrong with Z'ing a frame "IF" you have the skills to do a competent job. Far too often this is suggested as a cheap and easy way to get the job done. My feelings are that this encourages the inexperienced to take on a task that is above their head and results in an unsafe vehicle.
Articles-
"Refining Sierra"
Old 11-25-2009, 10:20 AM   #13
butterboy
Hey totally understand where your coming from. Z-ing a frame could be a cheap, dirty and unsafe way to get your truck low. I think if your going to do a "Z" you should be able to do it the right way..Now what is the right way? :
Old 11-25-2009, 11:56 AM   #14
N2TRUX
Happy to be here
N2TRUX's Avatar
Let me see if I can't find some resource posts. I know there are a few on here.
Did you look at the one that Kev2809 posted- LINK
Puropedo's project.
Articles-
"Refining Sierra"
Old 11-25-2009, 12:19 PM   #15
butterboy
Ya Puropedo's build thread!!! I have been studying it very close. Best thing I found for what I want to do.
Old 11-25-2009, 01:25 PM   #16
kev2809
low n' slo
kev2809's Avatar
same here. if your good at welding, there is like 0 cost in the notches except for material...and it gets super low
-_--_--_ _________
