Old 11-24-2009, 01:15 AM   #1
trukindud
trukindud's Avatar
67-68 rear ends
what rear ends came stock in 67-68?
64 buick skylark 65 buick skylark 67 chevy 2wd Lb 68 2w Lb 05 chevy colbalt
trukindud is offline   Reply With Quote
Old 11-24-2009, 01:17 AM   #2
breeh
Recovering 67-72 Addict
breeh's Avatar
Re: 67-68 rear ends
6 lug 12 bolt
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt.
"Friends call me cruzer cuz I like fast cars and fast women"
breeh is offline   Reply With Quote
Old 11-24-2009, 01:19 AM   #3
trukindud
trukindud's Avatar
Re: 67-68 rear ends
was there any othere options
Old 11-24-2009, 01:22 AM   #4
breeh
breeh's Avatar
Re: 67-68 rear ends
I guess I should have asked if it was a 1/2 or 3/4 ton. If a 3/4 ton then it should have an HO52 full floater.
Old 11-24-2009, 01:27 AM   #5
trukindud
trukindud's Avatar
Re: 67-68 rear ends
2wd cst c20 i think
Old 11-24-2009, 01:30 AM   #6
breeh
breeh's Avatar
Re: 67-68 rear ends
Okay, should be a corporate HO52 then unless changed in the last 40 years. If a leaf spring truck then there is a chance that it could be a Dana 60.
Old 11-24-2009, 01:34 AM   #7
trukindud
trukindud's Avatar
Re: 67-68 rear ends
Size:  86.8 KB this is the one that came out
Old 11-24-2009, 01:36 AM   #8
breeh
breeh's Avatar
Re: 67-68 rear ends
If that is an 8 lugger than I would say that is a Dana 60.
Old 11-24-2009, 01:39 AM   #9
trukindud
trukindud's Avatar
Re: 67-68 rear ends
6 lug
Old 11-24-2009, 02:05 AM   #10
breeh
breeh's Avatar
Re: 67-68 rear ends
Hmmm, 6 lug in a C20? 6 lugs implies 1/2 ton or C10. Should be a 12 bolt or maybe a Dana 44. Need to see the rear cover to ID.
Old 11-24-2009, 02:09 AM   #11
trukindud
trukindud's Avatar
Re: 67-68 rear ends
well i know its not a 12 bolt
Old 11-24-2009, 02:11 AM   #12
trukindud
trukindud's Avatar
Re: 67-68 rear ends
did chevy ever put a dana 44 in a 67 -68 truck
Old 11-24-2009, 02:15 AM   #13
shaneschevys
Its always something!
shaneschevys's Avatar
Re: 67-68 rear ends
I think they did in some of the leaf spring trucks. Is it a 10 bolt?
79 p10 stepvan
72 Short Fleetside
72 Suburban
67 GMC One Ton Flatbed
64 Short Fleetside
57 Chevy 2DR Hard Top
57 Chevy 2dr wagon
65 f*** short fleet
63 C 60 Flatbed
Member of the patina club
shaneschevys is offline   Reply With Quote
Old 11-24-2009, 02:20 AM   #14
trukindud
trukindud's Avatar
Re: 67-68 rear ends
its coil
Old 11-24-2009, 02:25 AM   #15
shaneschevys
Re: 67-68 rear ends
I guess they could have put them in coil spring trucks. I have always seen them in leaf spring trucks.
79 p10 stepvan
72 Short Fleetside
72 Suburban
64 Short Fleetside
57 Chevy 2dr wagon
65 f*** short fleet
63 C 60 Flatbed
Old 11-24-2009, 02:25 AM   #16
breeh
breeh's Avatar
Re: 67-68 rear ends
There were D44 put in these trucks. I personally have not seen one but have seen them pop up on this board several times. It is possible that a 6 lug D60 was swapped in later. On the dana's you can usually find a casting number in the webbing. Look for 44 or 60. If you had a picture of the cover we could at least ID if it is a dana.
Old 11-24-2009, 08:00 PM   #17
trukindud
trukindud's Avatar
Cool Re: 67-68 rear ends
[ATTACH]Name:  12345.jpg
Size:  29.0 KB[/ATTACH] is this what you were talking about or one of the othere numbers
Old 11-24-2009, 08:55 PM   #18
ERASER5
ERASER5's Avatar
Re: 67-68 rear ends
Looks like a Dana 60. My D-60 is 6 lug, but most are 8 lug. An original C20 would have 8 lugs every time.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 11-24-2009, 09:41 PM   #19
vectorit
What?
vectorit's Avatar
Re: 67-68 rear ends
I've only seen D-44's up front.
(A D-44 is my front axle)
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 11-24-2009, 11:39 PM   #20
project 67 sub
project 67 sub's Avatar
Re: 67-68 rear ends
mine had a 6 lug 10 bolt when i got mine, but not a dana 44. but now it has a 71-72 5 lug 12 bolt, with 76 c10 rear drum brakes on it
project 67 sub is offline   Reply With Quote
Old 11-25-2009, 12:28 AM   #21
breeh
breeh's Avatar
Re: 67-68 rear ends
Definitely a Dana and based on the casting number it looks like a D-60. Here is a link to another reference to this axle:
http://67-72chevytrucks.com/vboard/s....php?p=3615814
Old 11-25-2009, 12:54 AM   #22
trukindud
trukindud's Avatar
Re: 67-68 rear ends
thanks that was way use full so dose any one know what all the numbers stand for on the back
Old 11-25-2009, 02:37 AM   #23
68 C-10 Panel
68 C-10 Panel's Avatar
Re: 67-68 rear ends
To get all the info about the dana 60 go to pirate4x4.com and look it up. They have everything listed. I have one of these out of a dodge and am upgrading my corporate 10 bolt in my 88 blazer. Those damn 38.5" tires have a way of destroying 1/2 ton axles. If you need the link to the d60 page let me know and ill look up the link in my bookmarks.
68 C-10 Panel is offline   Reply With Quote
Old 11-25-2009, 10:30 AM   #24
chaosdsr
chaosdsr's Avatar
Re: 67-68 rear ends
Its a dana 60 for sure, there have been a few that popped up here but I have never seen an option for this on the 67-72 trucks. Heres another truck on the boards with one http://67-72chevytrucks.com/vboard/s....php?p=3615814
chaosdsr is offline   Reply With Quote
Old 11-25-2009, 01:59 PM   #25
trukindud
trukindud's Avatar
Re: 67-68 rear ends
yeah if you would that would be sweet!
