Old 11-24-2009, 12:24 PM   #1
fastrob
Someone please help
81 c10 350 i have antifreeze dripping out from under my dash onto the passeger side floor mat. anyone have this problem or know the solution... thanks
fastrob is offline   Reply With Quote
Old 11-24-2009, 12:32 PM   #2
Adams74Chevy
Adams74Chevy's Avatar
Re: Someone please help
sounds like a heater core leak. shouldn't be terrible to do verses newer import (or any newer) vehicles.
2006 Silverado Crew Cab 1500 4x4 5.3L automatic
1986 M1008 CUCV 6.2L Detroit Diesel TH400 4.56 Detroit Locker rear NP208
1973 K20 "Silverado" 350ci, HEI, TH350, NP203 with 2wd conversion, A/C, power windows,tilt wheel, dual tanks. My '73ish K20 thread My 5yo son claims it as his.
1987 V20 Custom Deluxe 350 TH400 NP208 "farm truck" getting parted out.
2016 Nissan Altima grocery getter/commuter
Adams74Chevy is offline   Reply With Quote
Old 11-24-2009, 12:39 PM   #3
TexasJeff
Don't Crush em Restore em
TexasJeff's Avatar
I would agree with Adam on this one, just changed mine out about a year ago, not to bad to do but did take a couple hours.
TexasJeff
2009 Silver with Linen Interior Cadillac DTS
1990 Red with White Top and Interior Ford Mustang GT convertible
1998 Red with Gray Interior, C3500 Chevy Crew Cab Dually
TexasJeff is offline   Reply With Quote
Old 11-24-2009, 12:43 PM   #4
fastrob
by chance would this b causing my windows to fog when driving? even with the defrost/defog on they r still very foggy
Old 11-24-2009, 12:43 PM   #5
Adams74Chevy
It definately will. and that intoxicating warm sweet smell too.
Old 11-24-2009, 12:48 PM   #6
fastrob
great thanks for the info... so its fairly easy to swap the core out? just take the dash apart?
Old 11-24-2009, 01:04 PM   #7
xrcr
It's not really the dash, it's under on the right side. Look where the lines go into the firewall and it's right behind that(duh...) it'll be covered by ductwork.
It's more of a pain than difficult. I don't bend like I used too.
xrcr is offline   Reply With Quote
Old 11-24-2009, 03:31 PM   #8
TDS-MN
The work will be done both under the hood and under the dash. Actually, the Haynes manual has a great write-up of the procedure. I'd guess a Chilton's would too probably, but I only have teh Haynes for my truck.
If your truck has A/C, the task might be a little harder than if you don't, but the heater core itself should cost you less than $30 I'd think, if I recall correctly.
As someone above mentioned, be thankful it's this truck, compared to many other vehicles that access is a LOT worse.
If you are realitively handy with wrenches, you can do this replacement and save a LOT of money versus what you'll pay to have a shop do it for you. No specialty tools required for this task.
TomS.
'98 S-10 Blazer 4dr 4wd - 4.3, AT, stock
'85 K-10 w/ 305, 700r4, np208, and RUST!
SOLD Dec 2014
TDS-MN is offline   Reply With Quote
Old 11-24-2009, 04:45 PM   #9
fastrob
i dnt have the time or the core to swap it out right now and its my daily driver... will it do any harm to drive with it like this till i get the part and time?
Old 11-24-2009, 04:55 PM   #10
cableguy0
the best thing to do before it completely lets loose and spews a lot of coolant out would be to just loops the hoses together. you could end up overheating the truck if you dont loop the hoses because of running low on coolant.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 11-24-2009, 05:11 PM   #11
fastrob
loop the hoses? the ones under the hood or under the dash
Old 11-24-2009, 05:15 PM   #12
chicklin
chicklin's Avatar
Under the hood. Look to see where the hoses go into the heater core on the passenger side. Unhook them and get a male-to-male barb fitting to hook them together so the coolant flows freely. Alternatively, you can completely remove one hose and hook the remaining one to the fitting on the engine where the other one was connected.
Have a bucket ready to catch all the coolant so you can put it back in. It's likely to be a messy job.
1954 Chevy 3600 - 235, 4-spd
1986 Chevy Suburban - 350, 700R4
chicklin is offline   Reply With Quote
Old 11-24-2009, 05:18 PM   #13
TDS-MN
Under the hood, the 2 that attach to the heater core.
Will mean that you have no heat/defrost. The fan will run but will not have any warm air to distribute. However, it will stop the leaking and steaming of the window at least.
If I remember right, my Non-A/C truck took not much more than 1 hour to swap out the heater core. If that helps you when trying to schedule time to work on it. I know the crunch felt when working on the daily driver, you have to get it done, can't afford surprises or delays. Not much fun under those circumstances.
TomS.
SOLD Dec 2014
Old 11-24-2009, 07:47 PM   #14
truckfan
truckfan's Avatar
Before you tear the dash out, make sure your extra gallon of coolant you keep under the seat did not spill......
1981 Chevy C30 440 Holmes 42K one owner miles
truckfan is offline   Reply With Quote
Old 11-25-2009, 12:10 AM   #15
fastrob
i know right! Guys thanks for all the info.
Old 11-25-2009, 12:36 AM   #16
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Remove the glove box for easy access. I did mine earlier this year.
You can find step by step instructions at www.autozone.com
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 11-25-2009, 02:23 AM   #17
longbedrick
longbedrick's Avatar
how badly do you need a heater? I'm sure it doesnt get THAT cold in North Carolina(j/k). as said above, loop your coolant lines together for a cheap fix. then you can drive around with a clean rag (is there such thing?) so you can periodically wipe down the windshield condensation. just be lucky you're not replacing a heater core in a '77 Firebird...NIGHTMARE
longbedrick is offline   Reply With Quote
Old 11-25-2009, 11:53 AM   #18
menace121978
menace121978's Avatar
figured i'd add 1 more thing... after you have either changed it or bypassed it make sure you dry up any anti freeze in the floorboards and dry out the carpet. if you dont the floor will start rusting.
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 11-25-2009, 01:23 PM   #19
Adams74Chevy
Originally Posted by longbedrick View Post
...just be lucky you're not replacing a heater core in a '77 Firebird...NIGHTMARE
My dad has a story about a buddy who had a firebird that needed a new heater core, needless to say his redneck engineering came into play...think sawzall and caulk and you can get the idea of how it came out and got "sealed" back together...
Old 11-25-2009, 06:03 PM   #20
fastrob
Thanks for all the input guys... took me an hour and a half. aint it funny how fixing something on your truck makes you feel like some big shot! Im tha friggin man
Old 11-28-2009, 10:11 AM   #21
TDS-MN
So true, it is a great feeling to successfully take care of stuff like that. Glad you were able to get it fixed.
TomS.
SOLD Dec 2014
