Badass
dogleg?
yeah i got some lol
went and did the front alignment on the truck for the 3rd time ![]() and did all that and the teacher walks up and clicks to a different page and shows the rear alignment.the back is off my 6% so how can i fix this.we didnt have time and wont be back in for a week
Think outside the box? -84c10 (1stcar)→My Build← ![]() -00 Saturn 5spd drop a gear and disappear! 1/4:13:90
dang its hot
Re: dogleg?
check your center pins on the leaf springs in back
Re: dogleg?
yeah the only thing that will cause this is the thrust angle of the rear axle(alignment). check the pins like grinch4om stated, or if the trucks ever been wrecked you could have some diamond in the frame.
77 CHEVY - SHORT BED STEP SIDE 2WD 02 CHEVY - EXT CAB SHORT BED Z71 7 INCHES OF LIFT |
Jonny
Re: dogleg?
You may also want to take a look at the bushings for your leaf springs they aren't something that typically wheres out, but they can. It doesn't take much to add up to 6 degrees.
1966 C30, Cummins, stacks, and a flat bed in progress... "Honor.....simply put, A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it." -AEC Hundley USNR |
Re: dogleg?
yea, maybe on of the brackets where the axle seats is off when u lowered it, i think the holes are offset and it can change the alignment if backwards
2006 GMC Sierra CCSB, 6.0 swap 2000 Chevy C3500 Crew Cab shortbed dually 1999 Chevy c2500 Crew Cab shortbed 1982 El Camino 350/350 1979 K5 2wd blazer bagged/bodied 1986 Monte Carlo SS 1991 Chevy CK SWB-67 clip and tailgate, bagged 350/700r4 1955 Chevy Bel Air 2014 Chevy Silverado ccsb |
Badass
Re: dogleg?
it has a flip kit.so it has a relocation bracket.
when i installed it.the pin on the bottom of the leaf spring was hitting the metal pease that the ubolts go threw and no its never been in a crash
Re: dogleg?
if im understanding right, there should be a hole in that piece for the pin? if there ismnt, or its not lined up, that could be the problem
| Bookmarks |
