11-24-2009, 06:15 PM | #1 |
Used cam, lifters and pushrods for a steal.. should I?
Going in my Vortec headed 350.
He wants $50 Camshaft, Hydraulic Flat Tappet, Advertised Duration 284/284, Lift .458/.458, Chevy, Small Block, Each Part Number: LUN-00016 Guy says they have about 100 miles on them before the truck they were in was totalled.
1972 Long Bed Cheyenne Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=285282 Waste my bandwidth and listen to some great tunes >> http://www.radioxenu.com (Live Shows with yours truly every Friday) |
11-24-2009, 06:24 PM | #2 |
Hollister Road Co.
Re: Used cam, lifters and pushrods for a steal.. should I?
Its only a steal if he marked the lifters in the order they were on the cam. Otherwise its $50 worth of cast iron.
11-24-2009, 06:31 PM | #3 | |
"IT IS BROKE IN THE LIFTERS ARE MARKED AS FOR POSITION"
1972 Long Bed Cheyenne Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=285282 Waste my bandwidth and listen to some great tunes >> http://www.radioxenu.com (Live Shows with yours truly every Friday) Last edited by 420am; 11-24-2009 at 06:31 PM. |
11-24-2009, 06:47 PM | #4 | |
then it is definetly well worth it....
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
11-24-2009, 06:48 PM | #5 |
72 Chevelle Club
In That case I would say go for it . I would reccommend that you buy some Lunati cam lube or Isky is what I use and lube it up like it was a new one when you put it in .
I Have The Right To Remain Silent,But Lack The Ability 1972 Chevelle ... Mine 2006 Trailblazer... Hers 2002 Buick century ... Kids 2002 K1500 Z-71 EXT CAB ... Daily Driver 2005 Rockwood Roo ... For Camping 1974 Harley-Davidson XLH Sportster 84'' stroker |
11-24-2009, 07:22 PM | #6 |
Old Duffer
Hate to go against the tide, but I wouldn't do it. After all the time and effort to install, the gaskets, and the fear factor, there's no guarantee that you won't wipe a lobe, then you'll have to do it all over again. Better to spring for new in this case. Why did the PO take it out?
"You get what you pay for." Just my $.02
'68 Short C20 Flatbed Dually w/ 292 4bbl, Langdon cast headers, and WC T5 trans. '81 G10 Shorty Van "Good judgement comes from experience, and a lot of that comes from bad judgement." Will Rogers "Under promise, then over achieve." |
11-24-2009, 07:22 PM | #7 |
For safety sake what do you guys think about buying new lifters? Trust that he got these marked in the right order.. or go safe and drop another $70?
11-24-2009, 07:23 PM | #8 | |
They were out of a 350 he had in an S10 that got totaled 3 days after the cam was installed.
11-24-2009, 07:35 PM | #9 |
Between Trucks...
I would go with new cam as well.
Beat it to fit, Paint it to match... Last edited by Sinister; 11-24-2009 at 07:35 PM. |
11-24-2009, 07:45 PM | #10 |
Old Duffer
Just curious, did the engine get broken? Why just pull the cam?
Your last comment about the lifters and my post hit the board at the same time.
11-24-2009, 08:04 PM | #11 |
I think he's going a different direction. It looks like a friend of his had this motor, did a rebuild then hit a cow 3 days after it was done and it totaled the truck. He bought the motor and is going with a bigger cam.
11-24-2009, 08:08 PM | #12 |
I usually only go with used if I know the guy personally. I just don't trust people.
11-24-2009, 08:11 PM | #13 |
I re-used a cam in my race truck and it lasted 26 laps. I would pass on a used cam. Go new and do it once.
11-24-2009, 08:12 PM | #14 |
Well I did some e-investigating and he has it posted on a forum that he has like 15k posts on as well. Same price, same story. So, that consoles me quite a bit. People generally don't **** where they eat.
11-24-2009, 08:13 PM | #15 |
This will be my first cam install.. worst case scenario it's just the practice run.
1972 Long Bed Cheyenne Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=285282 Waste my bandwidth and listen to some great tunes >> http://www.radioxenu.com (Live Shows with yours truly every Friday) Last edited by 420am; 11-24-2009 at 08:16 PM. |
11-24-2009, 08:15 PM | #16 |
I pulled the trigger on it. For $50 I guess I'll roll the dice and hope for the best.
Thanks for the advise though.. hopefully I won't be cursing myself later mumbling about some of you being right. Wouldn't be the first time.
