Old 11-25-2009, 03:11 PM   #1
Roadhammer
Roadhammer's Avatar
Wiring issue
I know this is a LOOOONG shot but ill explain the issue and maybe just maybe somebody will have had this problem before.
New Rebel Wire 9+3 circuit kit.
Everything is connected and working other than taillights working strangely.
The right hand tail light flashes on both directional signals. Brake lights are on all the time and regular tail lights work.
When i put pressure on the brake..The whole cluster flashes on the signal flasher?!?! so obviously something is wrong between the brakes and tail lights.
When i disconnect the brake light the right signal still flashes both ways.
Also should not that the front flashes work correctly other than the left flasher works key on or off and the right flasher only works with the key on.
Very confusing.
Jory
Any help advise or suggestions would be very much appreciated!
Roadhammer is offline   Reply With Quote
Old 11-25-2009, 05:52 PM   #2
bigblock96
bigblock96's Avatar
Re: Wiring issue
sounds like multible issues to me is it a double flasher unit or a single?
bigblock96 is offline   Reply With Quote
Old 11-25-2009, 05:53 PM   #3
Roadhammer
Roadhammer's Avatar
Re: Wiring issue
It has two seperate flasher plugs...
Jory
Old 11-25-2009, 05:56 PM   #4
bigblock96
bigblock96's Avatar
Re: Wiring issue
from the two flashers you should have like 6 wires correct?
Old 11-25-2009, 05:58 PM   #5
Roadhammer
Roadhammer's Avatar
Re: Wiring issue
to the column yes...
Jory
Old 11-25-2009, 06:07 PM   #6
bigblock96
bigblock96's Avatar
Re: Wiring issue
that will be 2 to the rear 2 to the front and 2 power.also do you have a wiring diagram for your truck?
Old 11-25-2009, 06:10 PM   #7
bigblock96
bigblock96's Avatar
Re: Wiring issue
this might help
Old 11-25-2009, 06:15 PM   #8
Roadhammer
Roadhammer's Avatar
Re: Wiring issue
your getting me thinking...places to look... ive never done anything much for wiring which is why i bought the kit...which was all labled and with instruction. Because when it comes to trouble shooting im terrible...
I do have a diagram
but it doesnt really completely apply to the rebelwire kit i bought.
Jory
Old 11-25-2009, 06:21 PM   #9
bigblock96
bigblock96's Avatar
Re: Wiring issue
just to help with colours of stock wire you may have the turn flasher and the hazard flasher wires hook up into each other?
