Old 11-26-2009, 11:26 AM   #1
DANTIP
DANTIP's Avatar
Pull Engine With Hood On?????
Is it possible/reasonable to try to pull engine without removing the hood? If I can avoid it I will.
Someone please save me if this is a really BAD idea!
DANTIP is offline   Reply With Quote
Old 11-26-2009, 11:32 AM   #2
JDL
JDL's Avatar
Re: Pull Engine With Hood On?????
I have done it. you tack off the carb and use a plate that bolts in place of it.
72 Chevy short step side with 454 air and tilt.
72 nova project car
63 chevy II drag car
Agency Iowa
JDL is offline   Reply With Quote
Old 11-26-2009, 11:47 AM   #3
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Here let me Help
NO!!!!!!!!
take a sharpy and trace the hood hindge on the hood ( spray paint works best ) it will leave a perfect place to put the hood back on
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 11-26-2009, 11:53 AM   #4
hayhauler71
hayhauler71's Avatar
x2 as long as the trans is not with it.
hayhauler71 is offline   Reply With Quote
Old 11-26-2009, 11:58 AM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Originally Posted by Hottrucks View Post
Here let me Help
NO!!!!!!!!
This gets my vote
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 11-26-2009, 11:59 AM   #6
CSGAS
optomistic ah-so
CSGAS's Avatar
It's a bad idea!!!
That is, "If you have to ask, it's a bad idea."
People who've removed a lot of engines know a lot of tricks picked up from many engine removals. With a few turns at it under your belt, you'll be able to predict which way the engine will swing and sway as you pull it, and what points you'll have to stop and adjust the engine height.
After pulling the engine with all safety precautions in place the first few times, then you can try pulling it with the hood on. Yes, it can be done, but to prevent damage to the hood you have to know which side of the hood latch and braces you need to start out on, what your main obstacles you'll have to work around getting past the linage, exhaust and steering, how to avoid putting the engine through the core support and so on. You'll decide if loosening the hood hinges or mounts will help or hinder you and if you want to take the wheels off and lower the front or not.
Thinking and planning won't anticipate everything, especially since every truck is unique. Do yours the safe way the first time, with an eye towards figuring out the answers for the next time.
When you get to the point that you don't have to ask us if it's a bad idea; that's when it's not a bad idea any longer.
Rubbing is Racin'
Ribbing is Bench Racin'
1970 C-10 lwb Fleetside. Originally 350 2-bbl 3-on-the-tree, m/b, m/w, m/s no a/c. Currently running on a '76 Camaro 305.
CSGAS is offline   Reply With Quote
Old 11-26-2009, 12:14 PM   #7
too much stuff
Roadtrip!
too much stuff's Avatar
I think it can be done, but it is only 4 bolts. Why take a chance?
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 11-26-2009, 12:16 PM   #8
fine69
fine69's Avatar
It can be done. But why take the chance of more damage than just taking the hood off?
My vote, BAD IDEA.
2008 Chevy HHR 1/2 panel.
1949 Chevy Panel truck(just sittin, waiting)
Board member #6
fine69 is offline   Reply With Quote
Old 11-26-2009, 12:21 PM   #9
Richard8971
Still livin the "dream" in '54
Richard8971's Avatar
When I took my motor out for my recent rebuild, I took the transmission out with the engine. Lots less work overall and yeah, you should take the hood off.
Takes only a minute and gives you a heck of allot more room to move around in. The trouble of removing the motor from the transmission before you remove it from the truck is a bit more work than taking them both out together with the hood removed.
You will need a load spreader (if that's what they are called) on your hoist to get the engine and transmission out at the same time. I have a 700R4 and I still had plenty of room to take them both out at the same time.
Don
Current build. 1954 Chevrolet 3800 "Ella" SOLD!
My '67 stepper "Tangerine Dream"
"Anything worth doing is worth doing right" James Dean
“When you have eliminated all which is impossible, then whatever remains, however improbable, must be the truth.”
Sherlock Holmes
"There is no spoon." Neo
Richard8971 is offline   Reply With Quote
Old 11-26-2009, 12:26 PM   #10
slomotion
Old Duffer
slomotion's Avatar
I wouldn't do it either. The easiest way I've discovered to re-locate the hood is to drill a 1/8th inch hole throught the hinge bracket and hood on both sides. Remove the hood. When it comes time to reassemble the hood, insert the bolts loosely, and jog the hood until you can put the drill through the holes. Tighten down the bolts, and remove the drill bits.
'68 Short C20 Flatbed Dually
w/ 292 4bbl, Langdon cast headers,
and WC T5 trans.
'81 G10 Shorty Van
"Good judgement comes from experience, and a lot of that comes from bad judgement." Will Rogers
"Under promise, then over achieve."
slomotion is offline   Reply With Quote
Old 11-26-2009, 12:31 PM   #11
BIG ORANGE
BIG ORANGE's Avatar
Here let me Help
NO!!!!!!!!
Listen to this guy, he knows what he is talking about. REMOVE the hood!!!
Things happen for a reason!
BIG ORANGE is offline   Reply With Quote
Old 11-26-2009, 12:32 PM   #12
clay68c10
clay68c10's Avatar
I like that drill bit idea.
I've pulled my BBC with the hood on, but I don't think I'd do it again. I'm voting to remove the hood.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 11-26-2009, 01:40 PM   #13
blukangoo
Neighborhood Pickle Slinger
blukangoo's Avatar
The idea with the drill bit sounds pretty good but like me, I don´t like to drill any holes anywhere unless I have to.
I marked mine with a fine tipped permanent marker and lined them back up when I put the hood back on.
I would take the hood off. If I remember right, it would have been in the way when I yanked my engine. I had the whole front end off anyways. That made it alot easier.
My C10 Diary
Our cars:
1966 Chevrolet Chevelle 396 - TH350
1968 Chevrolet C10/CST 327 TH400/375
1969 Corvette Stingray 350 - Muncie Manual Trans
1969 Chevrolet ElCamino 350 - TH400
1970 Cutlass Supreme Convertible - 350 Rocket - TH350
1973 Camaro LT - New Engine Done - TH350
1973 Corvette Convertible 454 - TH400
blukangoo is offline   Reply With Quote
Old 11-26-2009, 03:18 PM   #14
cdowns
cdowns's Avatar
the few minutes to remove hood is worth the effort//if you're working alone just hook up the hoist to the front of the hood unbolt the hinges after marking and walk the hood of without any damage//should take less than 12minutes to do the hood removal
Old 11-26-2009, 03:28 PM   #15
slomotion
Old Duffer
slomotion's Avatar
I know it's hard to drill the hole, but it's far less damage then chipping paint with a mis-aligned hood, and after everything is assembled the hole is so small you have to look for it to see it. All you need to do is use a "Q-tip" to put a dab of paint/sealer in the hole.
and WC T5 trans.
'81 G10 Shorty Van
Old 11-26-2009, 03:32 PM   #16
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
you could leave your home after thanksgiving dinner and contaminate the bathroom at the corner gas station just to keep from stinking your own up.
But more bad could come from it than good.
Old 11-26-2009, 03:51 PM   #17
slomotion
Old Duffer
slomotion's Avatar
Ummm, Longhorn.......only if I REALLY screwed up the hood!
and WC T5 trans.
'81 G10 Shorty Van
Old 11-26-2009, 06:49 PM   #18
jim zag
ENGINE BUILDER
jim zag's Avatar
It is easier with the hood off. Get some friends to help. I finally bought an engine tilter from my local Tractor Supply and you can r and r the engine with the transmission in the truck. I have done it. You just need to support the trans in the front with the engine out.
JIM ZAG
jim zag is offline   Reply With Quote
Old 11-26-2009, 07:56 PM   #19
Wrenchbender Ret
I have pulled hundreds of them & never pull the hood. I remove one hinge bolt & loosen the other & open it up further. Or take out the front bolt of the hinge & loosen the other & put a block of wood in it.
Wrenchbender Ret is offline   Reply With Quote
Old 11-26-2009, 11:37 PM   #20
chadio72
Truck Enthusiast
chadio72's Avatar
Ive done it lots of times, but only because i didnt have the needed help to pull the hood. trust me, its easier to deal with hoodless !
Chadio72 and his toys
67 C10 longfleet beater
68/01 K10 (4.8/4L65E project)
72 C30 Flatbed (400hp400)
66 Harley Davidson Shovelhead
chadio72 is offline   Reply With Quote
Old 11-27-2009, 02:37 AM   #21
j_cst_10
j_cst_10's Avatar
If your not scared about pulling an engine, but scared about pulling the hood off.... You may want to think twice about what your doing....but seriously.
j_cst_10 is offline   Reply With Quote
Old 11-27-2009, 09:32 AM   #22
68_chop_top
68_chop_top's Avatar
If you have a cherry picker, then removing the engine is possible with the hood on. Removing the transmission will make it easier.
If you only have a chain hoist, then removing the hood and tranny is mandatory!
Mine is chopped, has a clutch, and a big block.
68_chop_top is offline   Reply With Quote
Old 11-27-2009, 10:28 AM   #23
hotrod 80
mini truck racer
hotrod 80's Avatar
Yep , it can be done . It's close , but it can be done .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 12-05-2009, 08:07 PM   #24
Thealien
Thealien's Avatar
Hey that looks familiar
Old 12-05-2009, 08:34 PM   #25
I`d poop at the gas station...er,I mean take the hood off.
