Old 11-26-2009, 12:54 PM   #1
mycool72
mycool72's Avatar
What size of metal for frame building???
Im thinking of redoing the back side of my truck with a handbuilt frame that will allow the stock two link to travel through the notched area so it will lay down all the way. What kind/size of metal are you guys using to fab up your frames with? Any pics? Thanks...
mycool72 is offline   Reply With Quote
Old 11-26-2009, 01:37 PM   #2
independentcustoms
Re: What size of metal for frame building???
The easier way to accomplish this is to Z the stock rear. But if it were me I'd probably use 2"x4"x3/16"
independentcustoms is offline   Reply With Quote
Old 11-26-2009, 02:09 PM   #3
Puropedo
As mentioned, Zing your truck's stock rear would get you there (with a couple other mods) it is NOT the easiest way though. In my opinion building the back side from scratch would be easier. Use 2x4x3/16 tubing, nothing weaker.
Puropedo is offline   Reply With Quote
Old 11-26-2009, 03:07 PM   #4
FnLow69
FnLow69's Avatar
most people, myself included use 2x4 1/8" wall. 3/16 is overkill and is alot of added weight. All chassis company (that ive seen) use 1/8" wall box tube as well.
FnLow69 is offline   Reply With Quote
Old 11-26-2009, 03:16 PM   #5
MrBeast
high-Tech Red Neck
MrBeast's Avatar
1/8" 2x4" box tube weighs 2.6 lbs/ft
3/16" 2x4" box tube weighs 5.1 lbs/ft
1/4" 2x4" box tube weighs 7.7 lbs/ft
Now on a half ton, 1/8" should be strong enough for anything you need to do, if it were a 1 ton id say go 3/16"
Stock frames are 3/16" C channel, 1/8" 2x4 box tube is stronger than 1/4" 4" C channel.
"He used to be a pretty nice feller, now he's a welder!"
MrBeast is offline   Reply With Quote
Old 11-26-2009, 06:56 PM   #6
mycool72
mycool72's Avatar
Cool, thanks guys, yeah zing the back with stock rails would be easier but I want to build it up like I want it, I already have a SD notch with bags over axle but I am going to build it up to carry the bags on the stock two link and make room for arms to travel within the rails and add for the air tank etc...Ill post pics up when I get it going, thanks again!
