11-22-2009, 04:14 PM | #1 |
Problems with my eaton rear disc brake swap :(
OOOOOkay! So I purchased a set of DIY4x brackets to swap rear disc brakes on my 70 K20. I pulled the drums/hubs off and seperated them....went to put the rotor from a 73 4x4 on the hub and they dont fit! The mating surfaces do not touch. Do I need rotors from a 2wd or something? Any help is appreciated!
JP 70 K20 74 CJ5 |
12-09-2009, 01:31 PM | #2 |
Re: Problems with my eaton rear disc brake swap :(
Are you using 3/4 4x4 front rotors?
12-09-2009, 04:13 PM | #3 |
the studs have to be removed and the rotor placed on the back side of the hub then press the studs through
1949 Five Window, 1973 Step Side, 2000 Z71 |
12-09-2009, 04:16 PM | #4 |
exactly...It was late when I was trying this and put the rotor on the wrong side....dork is me!
JP 70 K20 74 CJ5 |
