Old 11-26-2009, 05:21 PM   #1
silvervic99stang
silvervic99stang's Avatar
ignition system
i am assuming my ignition system is still stock... what all do i need to make it a better than stock system new plugs, wires, cap and rotor? i dont know if its points either..
silvervic99stang is offline   Reply With Quote
Old 11-26-2009, 05:34 PM   #2
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Re: ignition system
Is it a 6 or 8?
Smitty
71 C10 283/3SPD Full Resto
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me https://67-72chevytrucks.com/vboard/...d.php?t=841215
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 11-26-2009, 05:53 PM   #3
silvervic99stang
Re: ignition system
292 inline 6 stock
Old 11-26-2009, 08:43 PM   #4
markeb01
Senior Enthusiast
markeb01's Avatar
Re: ignition system
If it's stock, it has points. The first thing I'd do is get rid of the points and install a Pertronix kit. They're bullet proof and easy to install. The link below may or may not be the exact one, but gets you close:
http://www.carshop-pertronix-ignitor...p/prx1162a.htm
They're available from many sources including Summit and Jegs. After that, as you've suggested, new plugs, wires, rotor and cap and you'll be set for many trouble free miles.
Old 11-27-2009, 12:54 AM   #5
Captainfab
60-66 Nut
Re: ignition system
I would also upgrade to a hotter coil as well.
Another option would be switching to a HEI distributor from a newer 250 6 cyl.
