![]() Join Date: Mar 2009
Changed Transmission need a slip yoke
If it isn't one thing it is another. Replaced my old engine with a rebuilt engine. Replaced 3 speed saginaw with a new process MY6 trans.
Now I need a 27 spline silp yoke.I should be able to use a 26 spline with wide groove. I need a replacement slip yoke that uses the same U joint that 1966 C10 drive shaft uses. I have another saginaw,date code s2s22,it has the 26 spline with the wide groove.Trans. is from a 1966 Chevy C10 truck.If I could date this trans. Could I order a slip yoke from that year trans? Thanks,Jimmy |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: Changed Transmission need a slip yoke
A TH350 uses a 27 spline out put. I'm not at all familar with your trans, but thought I'd mention this in case the TH350 slip yoke will work for you. Should be easy enough to find one of those.
I found the yoke,1310 series slip yoke is what I need.
Thanks,Jimmy |
