Old 01-22-2003, 02:22 AM   #1
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Red face Aluminum wheel backspacing.
Anyone here have any aluminum wheels with different backspacing? I'm curious if the outer edges are different for spoke models. For example take a look at my wheels in the picture below in my signature. I like the wheels but the front wider stance is killing my tires. I'm currently looking for infomation from the vendor or any other supplier of these PMR-068 wheels. I want a different backspacing for the front to tuck in the tires but I don't want to sacrifice the current "face" width of the wheel ring where the valve stem is located. These wheels have plenty of core center that I could probably have them shaved a little to tuck the wheels. However the weight handling characteristics will change. Since the difference between the back stance and the front is 1", Im thinking 1/2-3/4" shaved or backspacing change should tuck the tires under the fenders better.
If anyone has different back spacings for a smiliar aluminum wheels please let me know if the face ring size changes.
I'll be looking for new tires here really soon. Probably 245 this time around. The 235's are just to small for the 8" wheel.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 01-22-2003, 11:21 AM   #2
swervin ervin
You get what you pay for
swervin ervin's Avatar
Gerardo,
anytime you change the back space on a wheel, if it stays the same width, the part left on the front will have to change as well. The bow of the spokes is what you are referring to I'm guessing. They don't change this.
Also, our trucks have a 1" wider stance in front stock. When you drop it, it gets worse. I think mine is closer to 2" now. When they add shims to move the upper control arm out at the top to correct the camber, it pushes the tire/wheel out too.
I know your tire/wheel size, but what back space do the wheels have? My 17x8's are same as stock, 4". I have no problems at all with the 255/50's.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 01-22-2003, 12:37 PM   #3
LOHRTBT
BeWarE tHe eViL CrAnkTOe!
LOHRTBT's Avatar
Im running 5" BS and 245's up front
~Dave~
You can call me Mike, Mike Oxlong
- 1986 Chevy SWB - Stock for now
- 1986 Chevy Custom SWB *Stolen 6/26/05*
- 1985 Chevy SWB SOLD
- 1999 T/A Some mods
www.cardomain.com/id/ramairdave
AIM Screenname - Jester84
LOHRTBT is offline   Reply With Quote
Old 01-23-2003, 12:47 PM   #4
PHOENIX
I have some Weld Racing Drag Lites on my truck. I dont remember the exact back spacing but I can check if you would like.
Heres a pictures that kinda shows it:
http://www.73-87.com/~phoenix/Eddies83-02.jpg
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 01-24-2003, 01:13 PM   #5
gchemist
gchemist's Avatar
Eddie,
Thanks for the pics. Looks like 245/60 are my choice. I just need to rebuild the front end. The stock springs are just killing my tires.
Mike,
I guess bow is what you call it. Next time its warm around here I'll take off the wheel and check the back spacing. I'm guessing 3-4 inches.
Okay off for the day. I'm adding a new feature to my truck today get some gas milage back up to 16-18.
Old 01-26-2003, 04:25 PM   #6
MOUSE
stock is 4 1/2" fr. and 5" Rr. I was running 17x8"fr. and 17x9.5"Rr. 245/45 and 285/40 in the rear. MY prob. was the lack of adj. with the upper arms. BUT, since they got jacked 2wks. ago, im not real concerned.....
MOUSE is offline   Reply With Quote
Old 01-26-2003, 09:41 PM   #7
1FaastC10
1FaastC10's Avatar
Mouse, i hate to correct you again, but Mike is right, 4" is stock.
1FaastC10 is offline   Reply With Quote
