Old 11-26-2009, 08:25 PM   #1
southwilrise87
two questions
I have two questions. I just acquired my '65 lwb C10 so im still trying to gather information.
1. What size bolts are needed to mount the stock V8 engine mounts to the frame?
2. How hard is it to install a rebel wiring harness. I ask because I just received mine in the mail and have never done wiring before.
thanks
southwilrise87 is offline   Reply With Quote
Old 11-27-2009, 12:47 AM   #2
Captainfab
60-66 Nut
Re: two questions
3/8"-16 x 1" will be what you need along with some flat washers and lock nuts
I can't answer that for you as I haven't installed one. There is another member here that has recently, but it seems he had a couple of issues. I think it was Roadhammer?
thanks
Hope that helps
Old 11-27-2009, 10:15 AM   #3
southwilrise87
Re: two questions
cool thanks
Old 11-27-2009, 12:12 PM   #4
Roadhammer
Roadhammer's Avatar
Re: two questions
thanks[/QUOTE]
You tell me! Im still trying to figure this out and ive had it for a month...Im having the most trouble getting the taillights/brakelights to work properly off of the column wires.
Everything else was relatively simple if you follow the instructions. Ive also never wired anything before im my life. It will come in handy to have the stock wiring diagram aswell as the old harness to look back on.
Jory
Roadhammer is offline   Reply With Quote
Old 11-27-2009, 01:34 PM   #5
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Re: two questions
i used a kit from EZ wire that only cost me $165
i put it in in a few days
BTW im 15 and dont have that much experience
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 11-27-2009, 05:39 PM   #6
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Re: two questions
Roadhammer I had the same problem with my Painless kit and never got it to work. But when I took my bed off the frame I figured out i didn't have it grounded right. so check that.
The harnesses are really easy to install, as long as you can read where they go it's really easy.
One thing I will tell you if haven't already. Upgrade your Alt to an internal regulator instead of the stock external one, makes for a cleaner install.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 11-27-2009, 09:26 PM   #7
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Re: two questions
yeah like paul said make sure your lights are grounded properly i also had the same problem
Gage
Old 11-28-2009, 11:43 AM   #8
Roadhammer
Roadhammer's Avatar
Re: two questions
I got it figured last night...still dont fully understand it...but after almost completely pulling the wiring inthe dash...i tried starting it up....everything worked. Im guess i had low power and or the alternature somehow supplies brakelights in off of the fuse panel...dont understand it...but i now works.
