Old 11-26-2009, 10:23 PM   #1
southwilrise87
motor mounts
I have the metals pieces that attach to the frame and the crossmember. Are there other mounts that attach to the engine. This is my first classic truck and it came without an engine. Im getting ready to drop in the old engine from my camaro but for some reason I feel like Im missing something. Please help.
southwilrise87 is offline   Reply With Quote
Old 11-26-2009, 11:35 PM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: motor mounts
What year is your truck, and does it have a standard transmission or automatic. The mounts are different depending on what you have.
Old 11-27-2009, 12:18 AM   #3
Captainfab
60-66 Nut
Re: motor mounts
If you have a '63-'66 and if you have the original style frame brackets, then all you're lacking is the actual motor mounts and the bolts and heavy washers that attach them to the frame brackets. And of course the bolts to bolt the motor mounts to the block.
Old 11-27-2009, 10:17 AM   #4
southwilrise87
Re: motor mounts
thanks for the feedback. Its a '65 C10 with a three speed. I was looking through lmc truck and i think i found what i need.
Old 11-27-2009, 07:09 PM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: motor mounts
Unless he was installing an inline 6, then he'd need the brackets between the engine and rubber mounts.
