Old 11-27-2009, 10:12 AM   #1
jamesjensen1068
What's the cost to drop and bag a '72 Burb
Newbie here... so new I haven't even bought my Burb yet. I spoke with a guy I know who owns a company who manufactors aftermarket lift kits with air ride tech stuff to boot. Explaned to him that I was wanting to take a '72 Burb and drop and bag it. He quoted me " between $2000 to $4000. Is this really what it would cost or should I be looking elsewhere when the time comes. Could someone give me a breakdown of the parts needed to drop and bag a burb???
Thanks in advance to any who respond. The work and mods many of you have done is what's inspired me to persue a Burb as my "hotrod"
Cheers
jamesjensen1068 is offline   Reply With Quote
Old 11-27-2009, 05:17 PM   #2
Faster_than_you
Re: What's the cost to drop and bag a '72 Burb
Prices have probably changed since I looked into it for my 71 c20.
How low are you wanting to go? drag frame or just a little drop via air?
air ride was around 1200 in 05
drop spindles 400
drop control arms 300
c notch 100-250 depending on what brand you go with.
That is just the basic parts, without labor involved. look at hell of alot more if your taking it to a shop.
~Christopher L. Orr
71 c20, 454- Stolen While Deployed. dynoed at 550 ft lbs, 425 hp at 3000 rpm (mustang dyno). TH400 3500 stall.... etc, etc.
Faster_than_you is offline   Reply With Quote
Old 11-27-2009, 10:00 PM   #3
jamesjensen1068
Seems he was pretty right on with the price. How much would it be to c notch and drop without the air ride? Seems the bags would cause the price to be much, much more?
Old 11-27-2009, 10:17 PM   #4
kev2809
low n' slo
kev2809's Avatar
i bagged my own burb, but its not near as low as i want it so im gonna have to spend some more to get it where i want it. find your own kit, you can find some great deals from people who switch directions on their project. for the front, you need 2 bags, front bracket kit. rear you need 2 bags, and at least a c notch. that will get you about a 6 inch drop give or take. now figure up the tank(s), compressor(s), valves, fittings, water trap, switchbox, wiring, gauges, etc...you start getting pricey. to give you an idea, heres what i spent:
4 bags at 59.99 each, front back brackets/cups from suicidedoors - $300 give or take
compressor - used $90
tank - new $85
fittings - $120
switchbox - $30
8 3/8" valves - used $120
leader hose for compressor - $20
all 3 air gauges - $75
airline for gauges and bags - $40
still need - water trap, check valves, wiring kit, drop spindles, bolt in c notch.
thats just basic still need list. it can change on how you want your setup to be, and how low you want to go.
you can check out my thread to see how low a basic bag setup goes, i just dont have a notch on mine. im going to add drop spindles, recessed bag cups in my lca's. that will get me about 6 inches lower than what it is now. and for the rear i will put 2" drop blocks, rear "z", and a c notch for the axle. that will pull me down another 8 inches. see how easy $$ starts adding up. lol
on a side note, all these prices dont include labor, so far i have done every thing myself. so add that too....
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 11-28-2009, 12:03 AM   #5
OARNGESI
OARNGESI's Avatar
You can get
3/5 drop springs
a bolt in c notch
adjustable trackbar
and drop shocks for around 500
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 11-30-2009, 08:37 AM   #6
jamesjensen1068
Thumbs up Re: What's the cost to drop and bag a '72 Burb
Thanks everyone for the great info. Not sure which way I'll go on the drop. At least now I'll have an idea of the cost. Cheers
