Old 11-27-2009, 04:55 PM   #1
mikie 1954
Question no accesery on ignition switch
I have a 64 GMC 3/4 ton pu. the ignition switch has acc-off-run-start postions on it but when you put it in acc nothing works{radio ect} all other postions work as they should . is this right for this year truck or am i missing something? thanks for any help Mikie
mikie 1954 is offline   Reply With Quote
Old 11-27-2009, 09:39 PM   #2
Big Fenders
Re: no accesery on ignition switch
There is no acc. position on these chevy ign. switches. I just went through that problem with a new Painless harness. I ran a wire from the constant hot wire to a toggle switch and led indicator to the switched wire to the radio. That way you can have the radio on without the motor running. The led is there to remind me that it is on and to shut it off when parked.
Bob
Big Fenders is offline   Reply With Quote
Old 11-27-2009, 09:43 PM   #3
Big Fenders
[QUOTE=Big Fenders;3642479]There is no acc. position on these chevy ign. switches. I just went through that problem with a new Painless harness. I ran a wire from the constant hot wire to a toggle switch and led indicator to the switched wire to the radio. That way you can have the radio on without the motor running. The led is there to remind me that it is on and to shut it off when parked.Hope this helps
Bob
Old 11-27-2009, 10:49 PM   #4
mikie 1954
Smile Re: no accesery on ignition switch
THANKS BOB i thought maybe i missed something. will more than likely do something simailer , again thanks Mikie
Old 11-28-2009, 10:48 AM   #5
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
you can run to the parts store and pick up a 7 dollar ign switch that works great
thats what i did with mine
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 11-28-2009, 05:37 PM   #6
62gmc910
62gmc910's Avatar
The older gms 60-62 or 63 had an acc position and harness so the switch has probably been changed , so if you wanted you could probably run a wire with an inline fuse from the back of the switch to your acc. load
62 GMC 910 short fleetside 454 super t10 14 bolt
w/gov lock 70s c20 front discs (built in the 80s)
65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck)
63 GMC 950 camperized school bus, (Gus the bus)
350 4speed 2 speed rear
64 GMC 950 "spare" bus 283? 4speed detroit locker
53 GMC 1ton dual wheel bus
78 GMC c25 short course off road race truck(son's truck)
355 th400 14 bolt (www.wheel2wheel.ca)
88 Peterbilt 379 longhood (hauls race truck)
62gmc910 is offline   Reply With Quote
