Old 11-27-2009, 05:15 PM   #1
dj's70c-10
dj's70c-10's Avatar
Unhappy Another Drum to Disk Brake Conversion Question
I am swapping drum brakes on my 70 c-10 for disk brakes from a 72. Unfortunately, when I pulled the parts off the doner truck, which has now been crushed, I did not pull the center link. I am finding it impossible to locate this item. The salvage yards in my area no longed have these vehicles in their yards and the restoration parts houses carry the tie rod ends and connecting links but not the (drag link) center link. Apparently it is a collision item that has little demand. Can anyone steer me in the direction to locate a center link? I am pretty much dead in the water until I obtain one.
dj's70c-10 is offline   Reply With Quote
Old 11-27-2009, 05:35 PM   #2
70 Suburban
Rods
Re: Another Drum to Disk Brake Conversion Question
up to 89 should work
Just keepin it simple.
1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?)
1966 C-10 lwb 283 auto
1970 Suburban in pieces
1971 Blazer 4wd....restore someday. all factory CST
1972 Blazer 4wd parts truck still a roller
1972 GMC Sierra Grandee
1998 Chevy ext driver.
2005 F**D the wife drive...(cant fix women)
70 Suburban is offline   Reply With Quote
Old 11-27-2009, 05:50 PM   #3
dj's70c-10
dj's70c-10's Avatar
It was my understanding that 71 and 72 were interchangeable and 73 thru 87 were interchangeable, but not 71 thru 87. If I am wrong, my problem is solved. I am sure that a drag link made after 73 is available. Thanks.
Old 11-27-2009, 05:59 PM   #4
70 Suburban
Rods
i thoght it was 71 disk and up..... maybe im wrong
