Old 11-27-2009, 05:41 PM   #1
tcb-1
Nothing to see here.....
tcb-1's Avatar
Question Bed Removal Question
quick question gang.
has anyone drilled the bed-to-frame carriage bolt heads off.... from inside the bed?
mine are rusty and PB Blaster hasn't cut it. by the way, I have a wood floor and I want to keep it intact and not round off the washer seats in the wood.
I know it would be more labor intensive, but getting to the bolts with a tiger saw would take some fanagling.....
thanks in advance!!!!!
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 11-27-2009, 05:59 PM   #2
Boog
laying low
Boog's Avatar
Re: Bed Removal Question
Haven't drilled the heads off any. I'd just grab the hot wrench and hit it from the bottom side real quick.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 11-27-2009, 07:08 PM   #3
cdowns
cdowns's Avatar
i've ground the heads off with a cutoff wheel quite a few times on the bedbolts
Old 11-27-2009, 08:45 PM   #4
big mike71
big mike71's Avatar
Every bolt I try to take off breaks so let me have crack at them.
I'm not as good as I once was, But I'm as good once as I ever was.
big mike71 is offline   Reply With Quote
Old 11-27-2009, 08:50 PM   #5
Bob 68327
72 Chevelle Club
Bob 68327's Avatar
I would say center punch the head use a 3/8 bit to start go bigger if needed it won't be quick but it will work . My 2 cents
I Have The Right To Remain Silent,But Lack The Ability
1972 Chevelle ... Mine
2006 Trailblazer... Hers
2002 Buick century ... Kids
2002 K1500 Z-71 EXT CAB ... Daily Driver
2005 Rockwood Roo ... For Camping
1974 Harley-Davidson XLH Sportster 84'' stroker
Bob 68327 is offline   Reply With Quote
Old 11-27-2009, 09:18 PM   #6
pat 70/71
pat 70/71's Avatar
When I did my 70 short bed , it also was wooden bed with bolts that were rusted. I cut the mounting bolts from the under side of the bed with a sawsall (long blade) take your time and all will be good& buy new mounting hardware & keep it fun . ( I made my own wood bed, mahogany& black walnut) hope this helps. ...Pat
pat 70/71 is offline   Reply With Quote
Old 11-27-2009, 09:58 PM   #7
I did them on my fleetside. Not that bad as long as your bits are sharp and the holes are already rounded. I got it close to coming off, then I center punched the bolt down through the head.
Old 11-27-2009, 09:59 PM   #8
big mike71
big mike71's Avatar
Let's see some pics of the bed.
Old 11-27-2009, 10:27 PM   #9
msgross
msgross's Avatar
well, I didn't use finesse when I took mine apart... sorry...
I'm sure that you know that those bolts aren't centered in the washers, I'd go at them from the bottom...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 11-27-2009, 11:00 PM   #10
tcb-1
tcb-1's Avatar
well, I jumped in the bed with a few drill bits and went to town. drilling them out was a bit easier than the tiger saw. was able to save the washers and the washer recesses in the wood.
I want to save as much of the original bed components as possible. I am mounting my air tank and compressor for air bags under the bed. I want someone to be able to walk by this truck and not tell it's on air.
Mike, I can see you twisting a few bolts, your a bit on the MUSCULAR side!
Thanks for all the help gang!!
Doug
