Old 11-27-2009, 06:24 PM   #1
SBC RACING
Removing Bellhousing Crossmember?
Hey guys,
In the process of installing long tube headers on my 62' and ran into a problem with collector to bellhousing crossmember clearance. I have swapped out my SM420 for a Muncie M21 and also fabbed up an auto trans style crossmember that goes under the trans tailshaft. So my questions is, can i remove the bellhousing crossmember without causing any problems? My truck has the horse shoe style front motor mount so im a bit concerned that the trans crossmember has to support both the trans and the rear of the engine. However, im no expert so id like to hear everyone else's opinion/experience
Thanks so much
SBC RACING is offline   Reply With Quote
Old 11-27-2009, 11:23 PM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: Removing Bellhousing Crossmember?
You're going to need to convert to side engine mounts. With the horse shoe mount on the front and tail shaft mount in the rear, there will be nothing to keep the engine from twisting over from torque. In addition, if you're using an aluminum bell housing with a support span so far apart, there can be enough stress to cause pilot shaft/clutch alignment problems if not a broken bellhousing. You should be able to use the mounts shown on the attached link with a 1" spacer to make up for the difference in frame heights from the 62 to the later style frame.
http://67-72chevytrucks.com/vboard/s...d.php?t=369663
Old 11-29-2009, 12:47 AM   #3
Captainfab
60-66 Nut
I agree with markb01, You need to convert to side motor mounts. You can also use the '73-'87 style mounts for the conversion. The frame brackets from a 3/4 ton will work better than the ones from a 1/2 ton. However on the '60-'62's you will still need a spacer on top of the frame as shown on the link above.
Old 11-29-2009, 01:35 AM   #4
62gmc910
62gmc910's Avatar
Smile Re: Removing Bellhousing Crossmember?
I agree with the '73-80 mounts they are a lot solider, but we usually sectioned the mount plate to fit the frame it looks a lot cleaner especially if you make the cut below the mount but then you have to redrill the holes
62 GMC 910 short fleetside 454 super t10 14 bolt
w/gov lock 70s c20 front discs (built in the 80s)
65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck)
63 GMC 950 camperized school bus, (Gus the bus)
350 4speed 2 speed rear
64 GMC 950 "spare" bus 283? 4speed detroit locker
53 GMC 1ton dual wheel bus
78 GMC c25 short course off road race truck(son's truck)
355 th400 14 bolt (www.wheel2wheel.ca)
88 Peterbilt 379 longhood (hauls race truck)
62gmc910 is offline   Reply With Quote
