11-27-2009, 06:28 PM | #1 |
68 C10 SWB
Van Tilt.
So after searching, this is the link people were posting.
http://67-72chevytrucks.com/vboard/s...=dremel+column But its a dead link. Does anyone have any info regarding doing a van tilt colum on my 72 C10??? I'd rather not spend $700 on a new column... Thanx in advance for any and all help. |
11-27-2009, 07:05 PM | #2 |
Its a Truck Thing......
Re: Van Tilt.
See if you can find Kevin, Kevsclassics, he rebuilds them.
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
11-27-2009, 11:42 PM | #3 |
Re: Van Tilt.
You can use a van tilt if you modify a few parts. If you have an automatic it is necessary to relocate the neutral switch to the lower end on the column. If you are handy with taking the column apart you can recut the slot and move the switch. if you do not need a neutral switch it does not have to be moved. It will need to be removed so it will bolt up on a c10. Also the shaft at the bottom is longer and you can pull the shaft between the steering box and column and where it slides inside the shaft you should shorten the shaft about 2 inches this will allow movement in case of an accident. Do not try to do modifications if you are not sure how to safly do so. If that is the case purchase a truck column. It is cheaper than the hospital bills. Good Luck
11-27-2009, 11:55 PM | #4 |
laying low
Re: Van Tilt.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
11-28-2009, 12:05 AM | #5 |
Re: Van Tilt.
I KINDA WANT TO TRY ONE PF THESE http://cgi.ebay.com/ebaymotors/STREE...Q5fAccessories
70 SWB STEPSIDE 70 BLAZER 09 challenger |
11-28-2009, 10:53 AM | #6 | ||
68 C10 SWB
Re: Van Tilt.
So if i go to a junk yard and get a column form a chevy truck or van it will bolt in? Quote:
11-28-2009, 11:38 AM | #7 |
Re: Van Tilt.
My column came out of an 82 Van. Exact same as the ealier van columns.
1970 Nova 327/T5 (my 1st car) 1971 K-20 350/350/205 (winter DD) 1953 GMC Suburban 1968 Chevy Bel Air 1976 Chev C-10 1972 Skylark (suncoupe) 1 of 3943 made |
11-28-2009, 02:25 PM | #8 |
mini truck racer
Re: Van Tilt.
Yes , Chevy van that had the key on the dash . Moving the switch is not that big of a deal . I have done this twice without dis assembly of the column .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
11-29-2009, 05:01 AM | #9 |
Re: Van Tilt.
I have a van column in my truck. I have heard, that the ones with the key in the column are larger diameter and won't fit? I have a 4 spd., so neutral safety switch was removed. Collapsed the intermediate shaft to get proper length, and bolted it in. Piece of cake.
LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! 1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started. Last edited by OhioDan; 11-29-2009 at 05:03 AM. |
11-29-2009, 09:46 PM | #10 | |
Stepsides Are Bedder
Re: Van Tilt.
http://www.67-72chevytrucks.com/vboa...ad.php?t=63328 Works for me! |
11-29-2009, 11:01 PM | #11 |
PROJECT 7DEUCE
Re: Van Tilt.
I have never done one myself but I hear they slide right in with a few modifications.
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
11-30-2009, 11:17 AM | #12 |
68 C10 SWB
Re: Van Tilt.
So to be clear, i can use a column out of a van up to 82 with the key on the dash right?
I can probably still get one at the salvage yard.
"How much physical pain do you go through on a daily basis that you can directly attribute to your lack of intelligence?" -R0bman |
11-30-2009, 12:31 PM | #13 |
Re: Van Tilt.
Yes, you can use the van colum. The years are fuzzy for my understanding, but it helps to look for round lights in the van. If the colum DOES NOT have a key switch it should work. I just bought a trilt from a chevy motor home [year unknown] and it is simmilar to the van tilt with the exception of the steering shaft being shorter where it hooks to the intermediate shaft. Jim
11-30-2009, 08:48 PM | #14 |
Re: Van Tilt.
I'm not sure when they went from round to square headlights, but the round will for sure have the right style column. Don't bypass the square headlights without looking because my 82 van had square headlights.
12-01-2009, 02:07 PM | #15 |
68 C10 SWB
Re: Van Tilt.
Even moar bettar!
Found a salvage yard with 72's on the lot! Going this weekend to pull er out!
