Old 11-27-2009, 09:46 PM   #1
teeitup
Just like to part out trucks!!
teeitup's Avatar
Anyone ever had trouble getting lugnuts off
I've always been able to get them off but I have a truck here now that has a nice set of tires on white spoked wheels, and I can't get them broke loose. I don't have air, I've used my electric impact. I've tried a break over and a cheater, and no luck. A couple even rounded off now. I think they are rusted on. I sprayed them with PB blaster and still no luck. I don't know what to do with the ones that are rounded, I don't want to torch them because of the wheels. ANY HELP is appreciated. Thanks Randy
67 Chev swb stepside 4x4 283 4 speed SOLD
72 blazer 4x4 4 speed Cheyenne
72 GMC swb 4x4 fleet 4 speed, original paint
1958 Cameo (one of 1405 built, it was my dads)
2020 chevy Apex 4x4 crew cab
1969 Z28 with the 302
1980 chevy swb 4x4
1964 chevell Malibu SS
1976 K20, sold new originally out of my dads chevy dealership
Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure"
teeitup is offline   Reply With Quote
Old 11-27-2009, 09:52 PM   #2
Re: Anyone ever had trouble getting lugnuts off
Might be time for a nut splitter. I hate when they get that way.
I have also used my dremmel to split the nut, or at least part way which normally helps to break it loose
Old 11-27-2009, 09:53 PM   #3
mrh33916
Project '67 454
mrh33916's Avatar
I helped a friend get the lock nuts off his vehicle when he lost the key to them.
We took regular steel lug nuts and welded them to the lock nuts. It workd great and didn't hurt the wheels. This may work for you, the heat associated with welding another nut onto the existing nut may also help to break them loose.
mrh33916 is offline   Reply With Quote
Old 11-27-2009, 10:08 PM   #4
red69ss
Burnouts are therapeutic
red69ss's Avatar
I've heated them up with the torch and then put the impact on them with sucess, it would mess up the paint finish on the rims but nothing a spray bomb won't fix
1969 CHEVELLE SS
1972 C10 ALMOST DAILY DRIVER
1968 C10 RUSTBUCKET (MISSION IMPOSSIBLE)
1972 PONTIAC LEMANS CONVERTIBLE (WIFE'S CAR)
"My wife and I were happy for twenty years. Then we met." - Rodney Dangerfield
"The difference between genius and stupidity is that genius has its limits." - Einstein
red69ss is offline   Reply With Quote
Old 11-27-2009, 10:43 PM   #5
Just a suggestion coming from another direction.On the front,remove the spindle nuts and grind the back of the studs off.On the rear,pull the c-clis and do the same.This is the K1500 Sierra,right?
Old 11-28-2009, 12:41 AM   #6
Shane
Shane's Avatar
keep twisting till they break ... sounds like they are rusty enough that the lugs need replacing anyway.
Shane is offline   Reply With Quote
Old 11-28-2009, 01:02 AM   #7
OldBlue70C20
For the rounded ones you might try this.
I bought a truck this summer for my oldest son that had 20" rims on it and had the locking nuts on every stud. The problem was that the truck was a bank repo and there was no security key in the truck to get the nuts off. I did a little research by calling several of the tire and rim shops in my area. They all told me that if I brought the truck in that they could get the locks off with a "special" tool that they had and then they would sell me a new set with the key. One of them told me that the "special" tool about 95% of the time was a deep well socket that was slightly smaller than the lug nut and they drove it on with a hammer and then took the lug nuts off. In the other 5% they used a nut splitter. So on mine I used a metric socket in stead of the SAE that should have been used and I got all 20 nuts off this way. You might spray them down again and let them soak for a while then give it a try.
1970 C20 Longbed 307 CID 3 speed
OldBlue70C20 is offline   Reply With Quote
Old 11-28-2009, 03:48 AM   #8
70duramax
all the tool trucks carry twist sockets for damaged nuts spend the money and do it right get the right size socket, it'll be 1/2 drive put a breaker and a lenght of pipe and it will break loose. try it in the morning after a bowl of wheaties or later on that night after a few "sodas" lol
70duramax is offline   Reply With Quote
Old 11-28-2009, 03:50 AM   #9
70duramax
all the tool trucks carry twist sockets for damaged nuts spend the money and do it right get the right size socket, it'll be 1/2 drive put a breaker and a lenght of pipe and it will break loose. try it in the morning after a bowl of wheaties or later on that night after a few "sodas" lol another useful trick is to smack them head on with a BFH and than loosen
Old 11-28-2009, 10:02 AM   #10
The difference here is the threads are seized as well as not being able to put a wrench on them.
SOAK/HEAT/LEVERAGE...another thing is striking directly onto the lug and stud which breaks the bind.
Old 11-28-2009, 10:15 AM   #11
teeitup
teeitup's Avatar
Thanks guys, I'm headed out there this morning to try so more, no wheaties just a Dr. Pepper. Randy
1980 chevy swb 4x4
Old 11-28-2009, 12:52 PM   #12
Boog
laying low
Boog's Avatar
All this trouble over some white spokes?
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 11-28-2009, 03:04 PM   #13
slomotion
Old Duffer
slomotion's Avatar
I'm thinking he wants the tires.......
'68 Short C20 Flatbed Dually
w/ 292 4bbl, Langdon cast headers,
and WC T5 trans.
'81 G10 Shorty Van
"Good judgement comes from experience, and a lot of that comes from bad judgement." Will Rogers
"Under promise, then over achieve."
slomotion is offline   Reply With Quote
Old 11-28-2009, 05:52 PM   #14
teeitup
teeitup's Avatar
Got them off went to Napa and got a set of sockets that will fit anything 5/8 to over a inch, I'll get a pic of them soon and show you guys. You tap them on and they are tapered and they have edges that grab the nut, owrk real well. I did break a few studs off though, no biggy. $110 though. I'm sure I'll use them again. I was wanting the tires, not really the wheels, but not they are all OK
1980 chevy swb 4x4
Old 11-28-2009, 06:32 PM   #15
rsavage
rsavage's Avatar
Glad you got them off. Had a similar problem with a set of Aluminum wheels with lock nuts and no key. They were really nice rims so I didn't want to wreck them. Tried the special spiral sockets to get them off NG. Researched and found out the lock mfg. and got a key. Key was so thin wall that it rounded off before breaking the lock nuts loose.NG. Wrecked the two front center caps to pull the bearings and drums to grind off back of stud for the fronts. Wrecked the two rear center caps to get at the lug nuts (which are recessed in the wheel) to mig an old socket on the rear ones which did the trick for the rears. Cost to get those bast**ds off was $60 for new center caps, $35 for the special sockets that wouldn't grip, and $12 for a useless POS key that lasted a nanosecond. Oh and many hours and a can of PB Blast.
Sounds to me like you did well Randy.
rsavage is offline   Reply With Quote
Old 11-28-2009, 07:10 PM   #16
Gotta love that anti-seize (on your own stuff).
Old 11-29-2009, 12:48 PM   #17
teeitup
teeitup's Avatar
Here is what I got
1980 chevy swb 4x4
Old 11-29-2009, 02:35 PM   #18
I'll have to keep those in mind.
Glad you got them off!
