Old 11-27-2009, 11:08 PM   #1
Kaysenmc
Kaysenmc's Avatar
Question Differences in factory speedometer internals??
Here's the story.. About a week ago I was going to lube my 87s squeeking speedo cable and removed everything needed to get to the speedo. I always hate trying to unhook the cable from the speedometer head with such little space, so I unhooked the cable at the trans and fed the cable through the firewall for a little more working room. I noticed that the cast aluminum housing looked like it had some really bad casting marks (turned out to be cracks) on it on all sides. I proceeded to unhook the speed sensor (5.5mm bolt, I believe) then the cable, when the cast housing busted into probably 30 pieces. Gears, face, and odometer hit the floor but the part the cable hooks into was still stuck in the end of the cable.
So I have an 84 lwb I have been robbing parts off of and yanked the speedo without the sensor to swap into my 87. My 87's speedo had a gray drive gear that runs (use to run) the odometer, but in the one outta the 84 the same part is light yellow and is shaped differently.
Here's the problem... My speedometer has read slow by ten or so miles an hour (at 65)with my current powertrain setup (tbi 350, 700r4 (I do not know what speedometer gears it has in it) and 3.40 gear rearend (swapped from 2.73)). But now with the 84 speedometer I am reading about 15 mph fast at 65.
Heres the question... are 87 model speedometers a one year only piece (I know the faces will NOT interchange without modification) or are the speedos calibrated for different geared rearends from the factory? Or do I need to swap the speed sensor too? I have searched locally and online but have come up empty...
Thanks in advance and sorry for the long thread!
87 black silverado swb, tbi 350, 700r4, 3.40 gears. 2.5 drop spindles , 2 inches off stock coils, flip kit out back. cragers with radial ta's... ongoing piddle project!
1970 Olds rallye 350, street strip 403/350 3.73 posi. Looks stock/runnin 12's!
86 K5- SOLD!
Kaysenmc is offline   Reply With Quote
Old 11-28-2009, 09:21 AM   #2
b454rat
Re: Differences in factory speedometer internals??
I never heard of internals being different, I always thought they were the same.
I just looked at the speedo out of my 84, it doesnt' have the VSS on it, but the hole is there to bolt it on, just need a self tapper.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 11-28-2009, 09:45 AM   #3
68 TT
Still plays with trucks
68 TT's Avatar
Any pics? The two I have are both gray drive gears.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 11-28-2009, 08:07 PM   #4
Kaysenmc
Kaysenmc's Avatar
Well I got to the salvage yard a lil before they closed and all they had was some 100mph speedo's and an 89-91 that had the whole cluster robbed. So, I will keep everyone updated what I can find out
86 K5- SOLD!
Old 11-28-2009, 10:46 PM   #5
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Here's a site that has probably anything your looking for dealing with speedometer gears. A little ways down the page they have a ratio adapter that might work for you, give them a call to figure out exactly what you need. Hope this helps.
http://www.transmissioncenter.net/sp...n_______va.htm
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
