11-28-2009, 12:01 AM | #1 |
Squarebody Aficionado
Flip Kits
I was wondering you guys with flip kits how many leafs do you have in your pack? I currently have 4 leafs left cause i took a few out trying to get my truck where i wanted it and im afraid to take anymore out so im just going to do a flip but am i too late, do i need a new spring pack or will the flip still work with just 4 leafs in the pack?
11-28-2009, 12:21 AM | #2 |
I have car A.D.D.
Re: Flip Kits
I think you will be VERY low. I think Aaron (flamingbig10) had removed leafs and put them back because it was too low and too soft. I think it was him.
-Gerald Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace. 61 GMC Suburban SOLD The 86 build thread SOLD Are you a Colorado member?Click here. |
11-28-2009, 12:22 AM | #3 |
Re: Flip Kits
Fewer leafs will lessen the payload capacity while dropping the truck....
Mine is the HD spring pack w/8-leafs. When doing the flip-kit, the more leafs in the pack, the greater the drop. 5-leaf packs typically yield 5" drop; 8-leaf packs yield 6" drop.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 11-28-2009 at 12:23 AM. |
11-28-2009, 08:33 AM | #4 |
Re: Flip Kits
11-28-2009, 11:29 AM | #5 |
Happy to be here
Re: Flip Kits
Did you notice the topic was about "flip kits"? That puts the springs under the axle.
11-28-2009, 11:33 AM | #6 |
Re: Flip Kits
Ok.
Please explain why trucks w/more leafs in the pack yield more drop when installing a flip kit.
11-28-2009, 03:12 PM | #7 |
Formerly- 1972SuperCheyenne
Re: Flip Kits
I have 4 leafs in mine with a flip kit. No issues with mine so far.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. Last edited by STOCKISH; 11-28-2009 at 03:56 PM. |
11-28-2009, 04:26 PM | #8 |
6.0 powered square
Re: Flip Kits
It was me Gerald
flip kit with 3 leafs and drop shackles flip kit with 3 leafs flip kit with 5 leafs flip kit with 5 leafs and drop shackles
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 Last edited by flamingbig10; 11-30-2009 at 03:08 PM. |
11-29-2009, 03:34 PM | #9 |
Re: Flip Kits
11-29-2009, 03:38 PM | #10 |
Re: Flip Kits
They don't. I don't care of you run 13 leaf packs. See the pics above for an example. The axle sits ABOVE the TOP leaf. The amount of leaves under the top leaf only makes the pack stiffer.
11-29-2009, 07:13 PM | #11 |
Re: Flip Kits
i got 4 leafs and flip kit and it was a 6" drop
11-29-2009, 10:27 PM | #12 | |
Re: Flip Kits
11-29-2009, 10:35 PM | #13 |
its just $$$$$
Re: Flip Kits
11-29-2009, 10:55 PM | #14 |
yeller
Re: Flip Kits
Ceeten, you are missing the point.
Twitchin, LOVIN the 13 leaf pack in your illustration!
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
11-29-2009, 10:56 PM | #15 |
At the body shop.
Re: Flip Kits
Mine is flipped with 3 leafs from a light duty. It sits the same as it did with 7 leaf heavy duty pack. The lighter spring pack seems to have alot more arch to it.
" That didnt make it any newer " " Dont antique the equipment " |
11-29-2009, 10:57 PM | #16 |
At the body shop.
Re: Flip Kits
Can you feel the frustration lmao...
11-29-2009, 11:09 PM | #17 |
Re: Flip Kits
11-29-2009, 11:30 PM | #18 |
Happy to be here
Re: Flip Kits
Ok guys lets go easy on Ceeten here.
I can see why you think it doesn't have an impact. In the stock location with the springs above the axle, removing leafs lowers the truck for two reasons. The first one is static drop. By subtracting the thickness of the spring you know that the truck will be xx amount lower. At some point removing leaves also reduces the spring rate enough for the secondary means comes to play. By removing xx springs from the pack you will get approximately xx amount of drop. Now look at that same formula when applied to a flip kit. You are correct that it will no longer lower the truck by means of static displacement. This will however still have the same impact on the amount of drop that the reduced spring rate has accomplished. That drop will be combined with the total drop that the flip kit provides. Did that help?
11-30-2009, 02:23 AM | #19 |
Re: Flip Kits
LOL. We were talking about two different things. I see what you guy's are saying. I was under the impression that they were saying that you could get the truck lower by stacking leaves.
11-30-2009, 12:12 PM | #20 |
Re: Flip Kits
well there you go. sorry to anybody who thought i was coming off as rude. i was just tryin to explain a concept i thought to be rather simple. and here i am gettin all worked up when ceeten isnt even talkin about the same thing. sheesh.
11-30-2009, 02:13 PM | #21 |
Re: Flip Kits
It's all good man! No worries! I feel like an idiot.
