I need a 3/8" NPT to 3/4" hose end
ANyone know who would carry oe of these? I can find 3/8-5/8 but I really ahve to tighten a 3/4" hose down to fit it on the 5/8" and it is a matter of time before it takes a crap!
I had a V-8
Re: I need a 3/8" NPT to 3/4" hose end
Four Seasons part number 84780 is a straight fitting and part number 84777 is a 90* fitting--both are 3/4" hose to 3/8" NPT.
If you can't find one of these, you can always install a reducer in the hose from 3/4" to 5/8" then use the 5/8" hose to 3/8" NPT fitting. Obviously, this is not the most desireable method, but if it solves the problem....well, you know.
1972 K20 Suburban, 5.9L Cummins, Banks Power Pack, NV4500HD, NP205, H.A.D., D60/14FF ARB Link To Build: HERE. |
Watch out for your cornhole !
![]() Join Date: Jun 2003
What application are you using it in ?
3/8NPT to 3/4 hose fitting isn't used much of anywhere.
#4 | |
I know the threads is bigger then 3/8" but maybe I am off on the size a bit. I thought they were measuring inside hole on the NPT side. |
Heater hose bibs are 1/2 npt thread and either 5/8 or 3/4 hose. You get get both of them at the parts store in the HELP section.
