Need help with steering gearbox
Last week my gear box started leaking. so i looked around and bought a rebuilt one from the local napa for around $140 with an $80 core. Now onto the problem, I put it in today but now the truck feels like it has no power steering at all i open the pressure line going into the gearbox and it shoots out fluid. i open the return line and also fluid shoots out. what am i forgetting to do? i lifted up the front end and turn the wheel both sides check fluid level and its full. but once i put it back on the ground its hard to turn. Anybody have any suggestions?
Re: Need help with steering gearbox
If your other box worked and now the new one doesn't after bleeding then you may have a bad box.
Is the new box noisy? Sometimes it is hard to get all of the air out. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
Active Member
I gotta believe a bad box in this case
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles ![]() 18.5" x 31" Hoosier Pro Street Radials ![]() ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree ![]() |
how do i know if the power steering pump is circulating the fluid? is it like the radiator where you can see the fluid circulating?
#5 | |
You reservoir should not be full after install and turning the wheels Did you bleed it correctly? I would replace all hoses and fluid also when doing this. Probably needs it anyway unless you know the last time it was done. Jack the truck up with the tires off the ground. turn wheel all the way to left fill the reservoir to full cold. don't start truck. T Turn the fwheel back and forth until the level drops. If it does not drop nothing is happening. and air is in the system. Untill its out its not going to work Turn wheel slow NOT fast to allow air out do this until the level drops and does not drop anymore. Now pull the coil wire. crank the engine until you see if the level drops if it does there is still air. check for foaming too. If so go have a beer and wait 15 minute or whatever come back and do it again till there is none. If it still does not work its probably bad. or the piston is stuck inside. Last edited by mbgmike; 11-29-2009 at 11:04 AM. |
I had a similar problem after replacement of the gear box. That may be worth trying. remove the pressure line from the pump. Then remove the fitting. There is a very small screen there. Clean that screen. It doesn't take much too interfer with proper pressure. Then rebleed the system as others have suggested. This may solve your apparent lack of pressure in your gearbox and is easier than replacement of the gearbox. Good Luck.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
your saying take the pressure line out of the power steering pump not the gearbox? and clean the screen correct? both hoses have been replaced about 4 months ago when i replaced the power steering pump. and as far as the fluid it the reservoir was completely dry when i replaced the leaking gearbox and is there a way to get the piston unstuck?
ok problem fixed now. thanks to everyones reply. but the old man took one look and told me the power steering belt wasn't tight enough. i had a feeling i overlooked something. when i was turning the wheel you could see the puley of the powersteering pump just stop i tightened up and now its smooth. in case some one else runs into this problem.
