Old 11-29-2009, 12:04 AM   #1
supersean1978
rochester monojet
i have a 67 with a 292 I-6 with a remaned holley rochester monojet carb on it, I need to rebuild it or buy a new one but i need the part number for rebuild kit or to know where i can buy one that fits my 67 292....
supersean1978 is offline   Reply With Quote
Old 11-29-2009, 12:05 AM   #2
supersean1978
Re: rochester monojet
i bought a carb from summit a few months ago by matching year and engine size but it was not a monojet and was completely different that what i had on truck so i sent it back
Old 11-29-2009, 01:29 AM   #3
72lb4x4
Well, being bored I went to napaonline.com, entered 67 Chevy C10, selected 292 and searched for carb. It came back with 2 Holly carbs, and kits for Holley, Carter and Rochester.
Holley and Rochester are 2 different makes of carb, so I'd guess you have a Holley or Rochester, and I seem to recall that monojet is a Rochester name.
Rebuilding a one barrel carb isn't too tough so I'd go that route first.
72lb4x4 is offline   Reply With Quote
Old 11-29-2009, 01:32 AM   #4
silverstreak
Is there a number stamped on the side of the float bowl near the fuel line? It should be a 7 digit number begining with 70. I've gotten them from NAPA before just by giving them the carb number.
or, maybe give these guys a call
http://www.carburetion.com/index.htm
silverstreak is offline   Reply With Quote
Old 11-29-2009, 09:03 AM   #5
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I looked around for a carb a while back when I had stripped threads in the fuel inlet.They are getting hard to come by.I couldn't find one .Many had them listed but no one actually had one.I found a kit and a fuel inlet fitting.The kit came from Advanc and the fuel fitting was on the wall at the local "Speed Shop".Turned out the fuel fitting was the part that caused my leak.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 11-29-2009, 10:05 AM   #6
68gmsee
Active Member
68gmsee's Avatar
Did you mean "remanufactured by Holly Rochester carb?" The last one I got was also Holly remanufactured. If you have a pic, I can look through my old books and try to find out which one you have.
68gmsee is offline   Reply With Quote
Old 11-29-2009, 11:59 AM   #7
Wrenchbender Ret
First off, 67 didn't come with a Monojet. It originally had a model B. If it is a mono. the # should be on it vertically like Streak says. If it is a B they originaly had a brass tag on one of the air horn screws but they areusually long gone. The model B kit can be ordered from application since there is very little variations in them.
Wrenchbender Ret is offline   Reply With Quote
Old 11-29-2009, 12:09 PM   #8
Shyguy
Junior Member
Shyguy's Avatar
Beat me to it. My '67 l6 250 came with a model B.
The engine now in it is from a 70, I think, and has a the monojet.
Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
