Old 11-29-2009, 02:19 AM   #1
KrazyKevin
What have I gotten into
KrazyKevin's Avatar
Lowering question for 72' SWB Fleet
I'm still very new to the 67-72' scene. Learning everyday. But, I've seen many pics in the forums with trucks from all ride heights and tire sizes. A 3/5 on one truck doesn't even come close to looking the same on another.
What I'm wanting to know: Can I run 18's or 20's? If so, all I want to do is fill up my wheel well. I just want a level truck. I don't want tires inside the wheel well where I can't see the tops of the tires. So, if I run the 18's or 20's, will I still need to lower? Or will the tire size take care of what I need? If I do need to lower, what amount?
Kevin
1972 Chevy SWB Fleetside
Project BumbleBee
KrazyKevin is offline   Reply With Quote
Old 11-29-2009, 09:36 PM   #2
KrazyKevin
KrazyKevin's Avatar
Re: Lowering question for 72' SWB Fleet
ttt
Project BumbleBee
Old 11-29-2009, 10:09 PM   #3
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
yes you can run 18's or 20's the secret is to stay the same tire height
http://www.discounttire.com/dtcs/infoTireMath.dos
heres a link to play with so you can match up what you want.....remember the stock tire on your truck is about 29 1/2" tall which is a 235/75/15...I can run mine as low as it goes with te stock rallies so look for the same back spacing on the rims...I think 4 3/4" is the amount your looking for..then you can put in a 2" lowering block in back and either cut 1 loop off the front springs or go with 2" drop spindles...I think that will give you the look you want....you could also look at what you have and measure from the fender lip down to your tire to get an Idea of how much drop you want.....just stay with the same tire height and it will keep your speedo correct
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
