Doing some work on the 72 and went to reinstall the carrier bearing brcket and 3/8" bolts won't tighten up!! Can't get at them to tap for 7/16" so what tto do now? The bed is off the truck! Help!!!
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Re: PLEASE HELP-Bracket that holds carrier bearing on drive shaft
Is this the plate that mounts to the frame and then the carrier baearing mounts to it? If so mine have bolts with nuts?
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
It is under the back half of the cab. The plate on top has clearance holes for 3/8" and the bracket around the shaft is tapeed for 3/8" nc! The bolts will not tigten up nor is there enough room to drill and tap for 7/16!
Do i have to remove the entire drive shaft or? |
soonseeker.....i have complete bracket assembly its free ...let me know if ya still need:
edco joe thanks for the offer i will let you know. What i have found out this is a new unit (by previous pwner) and could it possibly be METRIC bolts and that why 3/8 nc will not tighten up? Going to stop into local bolt supplier in the a.m. ,what size is just a little bigger than 3/8? pitch?
