Old 11-29-2009, 12:12 PM   #1
hcaz095
Question Carb issues - accelerator pump?
So, I get some backfiring when I try to gve it more throttle quickly. It also helps if I pump the gas pedal progressively as I'm giving it more gas (like stairs). how would I confirm that it is the accel pump and not a vac leak? How do I cnfirm my carb? It is a California 72 with 350v8... Also, how do icheck if it is a th400 vs th350 turbo- hydromatic?
Zach
hcaz095 is offline   Reply With Quote
Old 11-29-2009, 12:28 PM   #2
Sinister
Between Trucks...
Sinister's Avatar
Re: Carb issues - accelerator pump?
Can't help with the carb issue, but you can I.D. the transmission by the shape of the pan. http://www.nastyz28.com/chevy-transm...tification.php
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 11-29-2009, 01:18 PM   #3
68gmsee
Active Member
68gmsee's Avatar
You can give the accelerator pump a quick visual check with a small flashlight.
Take the breather off the carb, run the truck for a minute or so -running it will insure you have a full bowl and the gas hasn't leaked out -then look in the throat as you manually move the throttle. You should see a good stream of gas squirting out. If it's real weak or if you don't see any, then the pump is supect or the float adjustment.
68gmsee is offline   Reply With Quote
Old 11-29-2009, 03:23 PM   #4
tim21391
tim21391's Avatar
maybe you got junk in the float bowl? are u still runnin points?
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 11-29-2009, 03:24 PM   #5
tim21391
tim21391's Avatar
my truc kwasnt running right so i wiggled the float and it solved that problem
