Old 01-22-2003, 01:03 PM   #1
cheyenne10
cheyenne10's Avatar
removing 4 spd shifter
What is the process for removing a stock shifter from SM465 transmission? Is it simple or involved?
Bob
cheyenne10 is offline   Reply With Quote
Old 01-22-2003, 01:10 PM   #2
Yukon Jack
Post Whore
Yukon Jack's Avatar
Push down on the shifter then their is a kind of cover that you rotate and then the cover will slip off, then the shifter will come right out.
Added tip, if you need to get the top cover off the SM465, the shifter needs to be in reverse about half way.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 01-22-2003, 01:58 PM   #3
cheyenne10
cheyenne10's Avatar
cover
So the shifter is held on with a kind of spring loaded lock-ring? I assume no tools required?
Bob
Old 01-22-2003, 02:02 PM   #4
jays68yak
jays68yak's Avatar
Ok what if you have a NP435?? How does it come off then?
1969 Chevy Project SWB Fleet, 20s, 5.3, t56, in the weeds.
1970 Chevy Truck cab on a 1979 Jimmy frame-8.1 liter 496 bbc/sm465/np203-jeds doubler-np205/d60/14bff Welded/42 tsls on recentered H1s
1998 Chevy Crew Cab K3500 SAS'd with hpd60, links and swayaway coilovers. 8.1l vortec DD/towrig
"I like long walks, especially when they are taken by people who annoy me. "
jays68yak is offline   Reply With Quote
Old 01-22-2003, 02:27 PM   #5
Yukon Jack
Post Whore
Yukon Jack's Avatar
Yep, no tools. No idea on the NP435, sorry.
Old 01-22-2003, 04:35 PM   #6
mikep
Used to have a truck
mikep's Avatar
I have an np 435. its real easy. I use a pair of channel locks opened up all the way and push down on the depressions in the lock collar and rotate it counterclockwise. The shift lever then pulls straight out. It looks harder than it is. Once you get the hang of it its a 3 second job.
No truck :-(
mikep is offline   Reply With Quote
