Old 11-29-2009, 01:35 PM   #1
hcaz095
Question Window & door issues
I have a few issues on my 72 that should get sorted out. First, both windows are fairly hard to roll down... Is it just the felts? They don't rattle very much... Is there something that needs to be lubricated in the door?
Also, my drivers door no longer locks with the key... It will unlock, but does not rotate clockwise. What do I have to do to fix this?
Zach
hcaz095 is offline   Reply With Quote
Old 11-29-2009, 01:45 PM   #2
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: Window & door issues
on the locking part, did it used to lock? (Do you have the right key to the lock is what I mean)
take your door pannel off, I greased the tracks its and X that moves along a track, grease the track and oil the middle of the X
I hope that made sense. Any ? just ask.
John
1999 Toyota Tacoma 4x4
Old 11-29-2009, 02:33 PM   #3
KMACD71
KMACD71's Avatar
Silicone spray the crap out of the felt window channels also. After replacing mine the windows were hard to roll up, silicone spray helped.
KMACD71 is offline   Reply With Quote
Old 11-29-2009, 03:06 PM   #4
cdowns
cdowns's Avatar
yep take the nner door panels off and clean and lubricat everything that is supposed to move//i like cleaning with wd40 then after its clean lubricate tracks rollers and regulator gears and pivot points with white lithium grease
Old 11-30-2009, 02:29 AM   #5
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
On your door locks, it may be two things. I had that same problem and found out it was a worn key. Got a different key and it worked fine. The other is you might try spraying a little graphite powder in your locks to free them up. Just my $.02.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
