Grandpa in the rustmobile...
Where do I wire electric choke up to in the fusebox?
Gonna wire up my electric choke today, where do I wire it to in my fusebox? And will need some help 'tuning' the choke (where do I set it at?)
thanks
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
Re: Where do I wire electric choke up to in the fusebox?
would It go to ign. unfused?
AMERICAN IRON ADDICT
You can but you really should have it go to ign. fused, or install a inline fuse to be safe. Also use a volt meter and make sure you have 12 volts at the panel or the choke won't work properly. If the carb is new try the factory setting first.
theres a spot on the fuse box that isnt use maybe there?
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
Well...Im not really sure but I'll look...Anybody know any spots on the fusebox I can wire this to?
Ive got it wired with no fuse, and the choke doesnt open close, but its also 55* outside. Is this correct? And what should my choke be set at?
![]() Join Date: Mar 2009
I wired mine to a fused terminal that is only powered when the ignition is on with a full 12 volts, that is what the Edelbrock manual said to do
If you don't have AC you can put it on the spade that is on the bottom left side of the fuse panel. This spade is fused and hot when the key is on. As for adjusting take the breather off make sure the engine is cold and turn the choke until the butterfly just barely closes. Turn the key on and the butterfly should open after a few seconds
69 Chevy 4x4 383 Power ![]() |
haysonj
THANKS going out there now! ![]()
I see an AC fuse... but no AC spade plug in?
(im staying out of the rain as long as I can )
The one that says CIG Is the one I was refering to. You should check it to see if its hot with the key on and not hot with the key off.
Yeah..thats what my cig. lighter is wired to.....
whata bout the one next to the fuel gauge?
Any off them will work if they are hot with the key on. Check to see if your lighter works with the key off If not you can splice into that wire
