#1 | |
Conversion Truck Addicted
What kind of manual Trans is good for a Dually 1Ton 6.2
i have been thinking if there are a better MANUAL Tranny out there where i will get better millage and a little more top end as my Muncie SM465 is kinda low geard might be good for long distance and heavy trailer towing but for a Daliy Driver idk
Thomas Quote:
Re: What kind of manual Trans is good for a Dually 1Ton 6.2
I whould recommend a NV4500 5 speed chevy and dodge used them starting in 92.
heres some specs. NV4500 Specs: Manufactured by New Venture Gear Synchronizers: Carbon fiber composite Input shaft: 1-1/8" 10 spline (V8 version - gasoline) Input shaft: 1-1/4" 10 spline (Diesel, V10 version) (dodge) 4x4 Output shaft: 1-1/2" 29 spline Input torque rating: 460 ft-lb (dodge HD version) Max GVWR: 16,000 lb Max GCVWR: 21,000 lb Cast Iron Case, Weight (with oil): 250 pounds Fluid Capacity: 8.5 pints Fill level is to the bottom edge of the fill plug hole. These are the ONLY lubricants recommended for the NV4500: 75W-90 Castrol Syntorque Synthetic Mopar Manual Transmission Lubricant (PN 4637579) GM Transmission oil (PN 12346191) NOTE: Syntorque is NOT the same as Castrol Syntech. Standard Transmission has the oil. 1-800-783-8726 Gear Ratio 1st 5.61 2nd 3.04 3rd 1.67 4th 1.00 5th 0.75 R 5.61* |
Resident of Here
Nv4500!
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
x3 on the nv4500
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 ![]() |
its not low geared, its 1:1 like every other non over drive man and auto trans.
you could also setup a t5, nv3500/3550, getrag, t56, or any other chevy 5spd. a 4500 will be the strongest and a t56 will probably be the most expensive. |
I would do a nv3500 or a nv4500 if I had the money.I too am cursed with the sm465 trans but I have been looking at a cheaper alt.It is the o/d box from
from ranger they run about $1400 and require little modifcation.The unit bolts in between your bellhousing and trans so what you have to do is shorten the driveshaft 7" and move your shifter hole back and make a hole for the o/d shifter. Here is the link and som info: http://www.high-impact.net/transmiss...roverdrive.htm The Ranger Torque Splitter is an auxiliary gear box that bolts in front of the standard Chevy, Ford and Land Cruiser 4 speed transmissions. This fully synchronized unit allows you to split your gears at any time. Just push in the clutch, grab the Ranger's shift lever, (You will have two shifters: one for your main trans and one for the Ranger) and shift. At any speed. The unit is available in either a 27% overdrive or a special order 17% underdrive. (Please call for availability on the 17% underdrive models.) Through the years it has gone through several design changes. Today's unit is cast aluminum, measuring 7-1/2" long. The gears are helical cut and the shifting mechanism is a short throw manual shift. The unit is built to handle 420 ft./lbs. of torque and has a G.V.W. rating of 25,000 lbs. This unit is ideal for towing applications or improving gas mileage by lowering the RPMs Last edited by kelgar50; 11-30-2009 at 12:27 AM. |
huh ???
Or you could go with a Gear Vendors OD unit behind the trans...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
Jonny
![]() I, personally, will never install an aftermarket od unit for that reason.
1966 C30, Cummins, stacks, and a flat bed in progress... "Honor.....simply put, A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it." -AEC Hundley USNR |
what trucks do you find this tranny in? year model etc?
Thanks. |
Resident of Here
DO NOT buy a T-5, NV3500, or Getrag! They will all fall apart or explode with that truck. NV4500 is best, it can handle everything. T56, not so much, it is a performance tranny. Not a truck tranny.
#13 |
Jonny
Which getrag are you talking about? Mine has over 200k on it and hasn't blown up, and yes it's behind a diesel. T-5's and 3500's light duty and will probably break the first time you try to haul anything heavier than a balloon.
#14 |
Resident of Here
The half ton chevy getrags and the 3/4 and 1 ton dodge getrags.
#15 |
Jonny
If it's the G360 you are refering to their only problem is that they like to leak and people don't like to check them in between fluid changes. Nothing likes to run w/o lube.
#16 |
NV4500..........sorry. That is if this would be the best all around tranny. Thought about putting a Tremec 6spd in but not sure what would be entailed with that other than the obvious cost. Truck will be more a driver than anything but would be hauling a bit.
#17 |
Small block,Big block? 1/2 ton, 3/4 ton? How much weight are you going to haul? If you have 1/2 ton I whould lean toward a NV3500. NV4500s are strong but heavy and 1st gear is really low.
#18 | |
....and thanks for the info thirdstreettito ![]() |
#19 |
Resident of Here
–GM Light truck
General Motors used the NV4500 as RPO MT8 & MW3 in 8500 + GVWR light trucks.[1] * 1992–1994 GMC & Chevrolet C/K 2500 and 3500 * 1995–2002 GMC & Chevrolet C/K 2500 and 3500 * 2004–2005 Chevrolet Silverado 2500HD and 3500 * 2004–2005 GMC Sierra 2500HD and 3500 –Dodge Ram Chrysler Corporation Dodge Truck division used the NV4500 as NVG4500 in "Standard" and "Heavy Duty" applications.[2] Shared Standard Duty & Heavy Duty Features: * Dodge NV4500 Transmission to bellhousing bolt pattern (shared with the 1995–2005 GM light trucks) * Dodge specific input shaft 7.5" long with .725" diameter pilot shaft diameter & spline count varies * Concentric internal hydraulic clutch slave cylinder with integrated throwout bearing * 1992.5-1997 2wd Gear drive speedometer in tailhousing Some 1998 may have gear drive * 1998-----UP 2wd no speedometer gear (VSS in axle) Standard Duty 1992.5–2005 order code DDP: * All Years have Dodge small block bellhousing to engine bolt pattern * 1992.5–2002 Used with 5.9 V8(5.2L v8 used NV3500) * 2003–2005 5.7 hemi offered with auto only * 1992.5 only 1" diameter 19 Spline input shaft * 1993-----UP 1.125" diameter 10 Spline input shaft * 1992.5---UP 2wd 30 spline output * 1992.5-2000 4wd 23 spline output * 2001-----UP 4wd 29 spline output Heavy Duty 1994–2005 order code DDX: * All Years used with 5.9 Cummins Turbo Diesel and 8.0 V-10 * All Years 5.9 Cummins Turbo Diesel & 8.0 V10 bellhousing to engine bolt pattern * All Years 1.25" diameter 10 Spline input shaft * All Years 2wd 31 spline output * All Years 4wd 29 spline output
#20 |
Check out the Spicer 3053A. Not sure if they still come as cheap as the article says but something to keep in mind. Some of the Clark 5 speed's that came in medium duty trucks also had an OD gear.
http://www.jpmagazine.com/techarticl...ion/index.html Also, the NV4500 comes pretty pricey by itself...but I've seen some complete trucks with them for cheap (wrecked, blown motor, etc)...cheaper for the whole truck than buying the trans alone. You may be able to pull it and all the associated parts then part out the truck and make your money back. Even taking the $200-$300 scrap metal value on the truck makes you money back.
1977 GMC Sierra Grande |
#21 |
I would have to say nv4500 or just put a gear vendors on what you have now.
#22 |
BAD BOW-Silverado XST
