help me with my turnsignals
hey all, as some of you might have read in the general discussion board, i was hit by a drunk driver on thanksgiving evening. well my car is totalled, which leaves my 63 as my daily driver for the time being. well i havent got all the loose ends tied such as the turn signals, and heater. well i bought a universal turn signal lever to install on my truck. the original is messed up and i need to take the column apart to fix that. ive never touched one before so i just need a temporary fix to keep it safe. well my question is, how do i hook it up? im in no way electrically inclined so i would appreciate a step by step if possible. i gotta drive her to school and on the freeway, so i want to make sure that they work, because there is fog some times and i want to avoid any accidents. thank you in advance.
A girl phoned me the other day and said... Come on over, there's nobody home. I went over. Nobody was home. -Rodney Dangerfield ![]() .......THE ROAD TO HELL IS PAVED WITH GOOD INTENTIONS..... ![]() ![]() |
Re: help me with my turnsignals
LOL i love that Sig
Im not sure how about to fix your prob but im sure you just go off the wires goin to the old signal
96 Burban Sold 99 Z71 Sold 65 C10 Sold 72 C10 Sold 87 Short Bed Lowered Daily Driver ![]() http://s623.photobucket.com/albums/tt314/sswagon/ http://www.chevygmcofkc.org/forums/forum.php |
OK you need some connectors , a test light and a helper or a mirror on a stand
First find the hot wire from the trucks harness, I am guessing you can cut the wires above the connector since you will probabbly replace the switch in the column some time . The replacement should have instructions with it I hope. Hook the hot wire (key on) to to the wire marked flasher there should be a wire that powers up when you step on the brake hook that to brake power try this stuff and post back and I will walk you through the rest
62 GMC 910 short fleetside 454 super t10 14 bolt w/gov lock 70s c20 front discs (built in the 80s) 65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck) 63 GMC 950 camperized school bus, (Gus the bus) 350 4speed 2 speed rear 64 GMC 950 "spare" bus 283? 4speed detroit locker 53 GMC 1ton dual wheel bus 78 GMC c25 short course off road race truck(son's truck) 355 th400 14 bolt (www.wheel2wheel.ca) 88 Peterbilt 379 longhood (hauls race truck) ![]() ![]() ![]() ![]() |
so do i cut here? where its circled? above the connector?
yes as far from the connector as practical
IS such a hurry to help I forgot to say i hope your OK
I would not just cut all the wires. The horn wire is also in that connector. Also remember that the front and rear turn signals are seperates. The easiest thing to do is use the test light. Also remember the brake lights also go through the turn signal switch.
so i have never used a test light what do i do? connect it it to the end of the connector and see if theres juice? also does anybody know the color coding? my truck is a 63 c10 and there are color coded wires, it would be easier to spice.
#9 | |
see the wire by it's self that is the horn , don't cut it ground the test light , check it for power at the fuse box try a bat terminal the light should light,if so push the brake pedal the wire should be green, power should light test light, release pedal wire should not light tester. Next turn on the key test for a hot wire if you don't find one retest the green by stepping on the brake (to make sure the test light works. Now DO these things and post back. I just looked at your pics Idon't see a flasher at the bottom of the fuse box if you don't have a flasher only the brake lights can work
62 GMC 910 short fleetside 454 super t10 14 bolt w/gov lock 70s c20 front discs (built in the 80s) 65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck) 63 GMC 950 camperized school bus, (Gus the bus) 350 4speed 2 speed rear 64 GMC 950 "spare" bus 283? 4speed detroit locker 53 GMC 1ton dual wheel bus 78 GMC c25 short course off road race truck(son's truck) 355 th400 14 bolt (www.wheel2wheel.ca) 88 Peterbilt 379 longhood (hauls race truck) ![]() ![]() ![]() ![]() Last edited by 62gmc910; 12-01-2009 at 09:35 PM. Reason: Noticed missing flasher??? |
ok so today i used the test light, and i found that this white wire lights up the test light when the brake is applied.so i spliced the red wire that says flasher to it. i tested the rest of the wires in that harness, and i couldnt find a hot wire that was key on hot. so i figure i can run the power to the junction box where it says ignition unfused. i have an inline fuse from there. so at this point i dont know what to do. i couldnt get it to get power, should it be grounded to work? like i said im still learning
A girl phoned me the other day and said... Come on over, there's nobody home. I went over. Nobody was home. -Rodney Dangerfield ![]() .......THE ROAD TO HELL IS PAVED WITH GOOD INTENTIONS..... ![]() ![]() Last edited by 63deluxfleet; 12-04-2009 at 08:10 PM. |
The red wire does not hook to the white . look at your fuse box see the bottom right 2 female wire tab holes, the signal flasher goes there one should be powered (key on , the other feeds the signal switch this may be all that is wrong with your signals, BTW it's hard to help you if you don' t stick with it
sorry, i just got paid today and i bought the test light. so im sorry for bieng late on the reply
#13 |
So do you see where I mean about the flasher missing
