Old 11-29-2009, 06:13 PM   #1
Flat 67
Junior Member
Flat 67's Avatar
Heater Blower Fan Upgrade....
After doing lots of research I replaced my non a/c heater blower motor in my 67 with a a/c heater blower motor. Supposedly, this is a common upgrade. But, when you do this, the fuse 10amp fuse has to be replaced with a 25amp fuse. My question is do I just pull out the 10 amp fuse in the fuse box and replace it with a 25amp in the same location and are there any other modifications needed? Just being cautious before I start frying wires. Thanks for the help.........Flat 67
Flat 67 is offline   Reply With Quote
Old 11-29-2009, 06:23 PM   #2
haysonj
haysonj's Avatar
Re: Heater Blower Fan Upgrade....
Originally Posted by Flat 67 View Post
After doing lots of research I replaced my non a/c heater blower motor in my 67 with a a/c heater blower motor. Supposedly, this is a common upgrade. But, when you do this, the fuse 10amp fuse has to be replaced with a 25amp fuse. My question is do I just pull out the 10 amp fuse in the fuse box and replace it with a 25amp in the same location and are there any other modifications needed. Just being cautious before I start frying wires. Thanks for the help.........Flat 67
Should be good because that's what they do when they add AC to the truck.
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
